Old 07-30-2003, 08:35 PM
engineerjoel engineerjoel is offline
Default Dead Fader on Fader Pack
Besides the Procontrol mysteriously freezing up, Now I've got a dead fader on one of my fader packs......though it does quickly slam to the top and quickly slam to the bottom during each time I power-up or cycle-power the unit. But after that, the fader is completely dead....the fader doesn't even move when run the "test Faders" under Utilities. [img]images/icons/mad.gif[/img]
Is this an easy procedure to replace? What's the cost?
Old 07-31-2003, 05:09 AM
stevegalante stevegalante is offline
Default Re: Dead Fader on Fader Pack
Hi engineerjoel I've gone through a similar situation, I've ordered a new fader but when I opened PC to replace it I disconnected and re-connected the nonworking fader cable and it worked perfectly...
http://www.stevegalante.com
Old 07-31-2003, 06:51 AM
airwavejoel airwavejoel is offline
Steve,
Thanks for the info. I'll definitely give your recommendation a try. Hope the fix is that simple.
Joel
Old 07-31-2003, 11:02 AM
Roy Pahlman Roy Pahlman is offline
I have one fader pack I have replaced 3 faders and 1 that has not had one failure. Hmmmm..... Once I was out of warranty, the cost is about $200 if I remember correctly. I have had faders come back to life as well but it was just a last hurrah before it failed for good. Good Luck!!
Old 08-28-2003, 11:05 AM
Well, after several weeks of useless service, the Dead Fader has finally come back to life. I suspect that it may be that the connection is not quite
totally 100% secure. I haven't had time to dissasemble the unit to double check....just glad to see that's it's working properly again.
Dead Fader Pack TAFE ProControl, Control|24, Command|8 1 10-24-2008 09:31 AM
Damaged Fader on Fader Pack joesgarage ProControl, Control|24, Command|8 2 10-14-2006 02:26 PM
Dead Fader. Drew Mazurek ProControl, Control|24, Command|8 1 10-29-2005 02:32 PM
'Fader Pack' and ProControl Fader order issue Ciaran ProControl, Control|24, Command|8 2 03-21-2005 11:58 PM
Dead Fader Prelude Studios ProControl, Control|24, Command|8 3 02-03-2005 09:52 AM
