Old 05-23-2023, 01:12 AM
musicman1985 musicman1985 is offline
Default Unable to record audio
Hello everyone,
I am using Pro Tools Intro on MacOs Monterey and when I try to record an audio track I get the annoying message "Unable to create record files for one or more tracks. Check your disk allocation and drive permissions." If anybody knows what to do I would be thankful. I already granted full disk permission to pro tools.
Old 05-23-2023, 01:58 AM
Sardi Sardi is offline
Default Re: Unable to record audio
As the error message states, you need to make sure the correct path is set in the Disk Allocation tab within the setup menu.
Set it to wherever you want to record to and carry on. If its set to an external drive and thats not mounted, thats more than likely your problem.
Old 05-23-2023, 03:07 AM
Yes I run my mac from external ssd.
Old 05-23-2023, 03:40 AM
Does this mean I can't use Pro Tools?
Old 05-23-2023, 05:05 AM
JFreak's Avatar
JFreak JFreak is online now
Go to workspace and set your external drive to record mode.
Janne
Old 05-23-2023, 05:38 AM
No. Thats not what it means.
I’m not sure how to explain it simpler than I have. There is a disk allocation setting in Pro Tools and you need to make sure it is set to the correct drive you’re trying to record to.
Perhaps this will spell it out clearer for you?
https://www.pro-tools-expert.com/hom...llocation-tips
Old 05-23-2023, 09:10 AM
This^^^^
Scott Gatteño
Old 05-23-2023, 09:37 AM
Tweakhead Tweakhead is offline
Step 1. If it's a newly purchased external drive, always make sure it's formatted correctly. If it's not, do that first using Disk Utility. see Avid's instructions : https://avid.secure.force.com/pkb/ar...with-Pro-Tools
or, when you write :
do you mean you're booting from an external SSD ? and you're also trying to use that boot drive as a Record Volume on the top-level of the drive (as opposed to creating a session on the current user/desktop) ?
Old 05-23-2023, 01:03 PM
Yes I'm booting from external ssd (apfs). I checked all the permissions for disk allocation . I searched for similar topics and someone stated that it works only with internal hard drive. Thanks anyway.
Old 05-23-2023, 01:13 PM
yes, but where precisely are you trying to actually create the session ?
on your Desktop ? or on the top level of the "Macintosh HD" ?
If it's your Desktop, try launching Disk Utility, run First Aid on the boot SSD, restart.
Re-check Workspace permissions.
Try again.
You are logged in as an Admin-level user, correct ?
Unable to record Kurzweil audio engine in PT11 insightsono macOS 1 04-27-2018 10:16 PM
Unable to Record (digitize) a Regular Midi Track to an Audio Track JuicyMusic macOS 9 02-27-2013 08:52 AM
Unable to record live audio Phresh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-29-2011 02:27 PM
Unable to Record BFD Audio paxfax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-19-2009 02:49 AM
unable to make my FW drive "audio record volume" andycopeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-18-2008 08:11 AM
