Old 09-27-2017, 09:53 AM
J.D. Andrew J.D. Andrew is offline
Default OMF Import problem [solved]
I'm getting this error on OMF import. I've searched but haven't found this exact error line. Some are close. Never saw an exact conclusion/fix.
Could not complete the Import Tracks command because Assertion in "/Volumes/Development/Code/203409/ProTools/NewFileLibs/PtAAF/OMF/OMF_Property.h", line 263.
I've spent 4 days doing the same tasks. Make session in premiere, export OMF and mix in pro tools. I'm not going to import 1000 files into pro tools and manually spot them to their time stamp. This is foreign language re-dubs.
Today I can't get pro tools to import the OMF.
12,8.1, 2017 MacBook Pro OS 10.12.6
Old 09-27-2017, 10:17 AM
Default Re: OMF Import problem
I figured it out. For some reason a file was thinking its timestamp was around the 24 hour mark, so the session was too long to import.
AAF import after track names disappear [SOLVED] bohitomi Post - Surround - Video 11 01-26-2018 07:33 AM
How to import multiple audio files onto one track?[solved] ergalthema Pro Tools 11 1 01-28-2017 08:38 AM
Import Session Data issue [solved] tascamtam Pro Tools 12 9 11-16-2016 12:00 PM
c24 problem SOLVED! bjnelson ICON & C|24 0 04-23-2004 06:24 PM
OSX/6.0 problem solved Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-05-2003 04:39 PM
