Old 09-17-2017, 05:02 PM
strangedaysuk strangedaysuk is offline
Default Pro Tools and RME ADAT 1+2
I recently had a big issue recording in Pro Tools with the Babyface Pro (not sure if this affects other DAW's). I was able to record on every input other than ADAT 1+2. I could see the audio in Total mix but I had absolutely no luck when setting these channels in pro tools at getting any signal in. In the end I was down 2 channels and very frustrated. I had another engineer in the session who was also clueless.
So what do I need to do to get ADAT 1+2 to record in pro tools.
Please note every other channel worked fine, but I know ADAT 1+2 also do SPDIF and wondered if this confused Pro Tools.
Running PT 12.6 - on a Mac OS Sierra.
Old 09-17-2017, 06:58 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Pro Tools and RME ADAT 1+2
What does you I/O configuration in Pro Tools look like?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-25-2017, 01:39 AM
Its as expected all inputs are assigned correctly.
I've used other devices with ADAT (and my Behringer ADA8000 pre amps) without an issue.
For some reason Pro Tools cannot see the Adat 1+2. Bit of a mystery and on the RME forums others have reported the same problem with no solution.
Has anyone else got the Babyface pro and used ADAT in PT?
Old 09-26-2017, 08:53 AM
I'm not having any luck with this at all - its very bizarre, it sounds like a PT issue but perhaps the way it sees the Babyface?
ADAT use with Pro Tools RussMiller Tips & Tricks 2 01-01-2016 09:13 AM
Adat I/O into pro tools Mpowered??? jomeo69 Pro Tools M-Powered (Mac) 4 03-21-2007 04:13 AM
ADAT WITH PRO TOOLS LE STUDIO A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-19-2004 08:18 AM
ADAT to Pro Tools j old school 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-25-2002 10:09 AM
40 tracks of Adat on Pro tools REC Studio Tips & Tricks 1 07-11-2000 12:13 AM
