EuCon setup for several devices and workstations
I have a little problem setting up my controllers (Artist Control, Artist Mix and Pro Tools Control) to work with three different Pro Tools workstations. My main setup ist Pro Tools 10 HD using Artist Control and Artist Mix with EuCon 2.7.1 on Mac OS 10.6.8. The second system is Pro Tools 11.x HD with EuCon 3.21 on Mac OS 10.8.5 that works flawlessly with the two controllers as well. My third system is Pro Tools 12.5 HD with EuCon 3.4 on Mac OS 10.10.2 that works flawlessly with the iPad App but not with the other ones. Ideally I would like to be able to use all three devices with all three systems. Is that possible? Is there a EuCon version that covers all those Mac OS and Pro Tools versions? Actually there are funny anomalies in EuCon: 2.7.1 recognizes the iPad App but can't add it to the My Surfaces list. EuCon 3.21 does not see the iPad App at all. EuCon 3.4 on the newest system sees the App and the Artist Mix but not the Artist Control. Maybe it's a firmware thing Any help appreciated. Best Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
Re: EuCon setup for several devices and workstations
I am confused on how you can physically run 3 different systems from the same working position? In any case, some issue may be due to the different versions of PT and different versions of Eucon(which might require different firmware in the Artist hardware). As for Control and the iPad, what do you have for a router? I found I had much better(and consistent) communication with a 5G dual-band router(so if you have a cheap router, that may be the issue)
As Albee said, its the firmware update on each Eucon version on the Artist series units so running on all systems with the same units is a no go.
Thanks for your answers. Artist Control and Mix work without a problem on PT10 (with EuCon 2.71, MacOS 10.6.8) and PT11 (with EuCon 3.21, MacOS 10.8.5). There has been no need to change the firmware so far. Now I added the iPad App with the very new EuCon and the anomalies started...
Btw: I'm working in two rooms, one has two workstations the other one only one. I'm taking the units with me if I move to the other room. Best Mark
How Can I Prevent Others From Hijacking My Eucon Devices? | Picture Start | Artist Series | 5 | 11-10-2015 05:56 PM |
The right setup for 2 workstations | HiLoc | Artist Series | 0 | 03-29-2012 12:57 AM |
IO Setup & Multiple S/PDIF Devices | ac30fan | macOS | 1 | 03-23-2012 12:56 PM |
VirtualVTR setup with these devices.... | AVGuru1 | Pro Tools TDM Systems (Mac) | 1 | 01-03-2003 10:40 PM |
Need best setup with 2 midi devices and a mixer!! | MoeMoney | Tips & Tricks | 0 | 06-23-2002 06:39 PM |
