Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 05-24-2013, 09:25 PM
Mr. Kelly Mr. Kelly is offline
Default PT10 & Waves Ilok problem
What else is new?
I just installed PT 10 on a fresh install of Windows 7. All was well with the Ilok licensing... until I installed Waves V6.8. Now, PT shows an error calling for the Ilok.
I've tried reinstalling everything twice (PT, Ilok drivers, Waves), with the first time having to "restore" the computer to prior to everything being installed (nothing else cleared the error). Simple uninstall of PT or Waves didn't clear the problem. I uninstalled all the Ilok files, downloaded new copies, re-installed them all, and PT worked, but as soon as I reloaded the Waves V6 (a fresh file from Waves)... PT showed another Ilok error.
This is really frustrating. I did a bunch of research on here, followed laborious suggestions, and twice this has happened.
There are, evidently, additional licenses on my Ilok for trial versions. Any connection?
Any thoughts? Is this for Waves to figure out?
Old 05-24-2013, 11:42 PM
danander11 danander11 is offline
Default Re: PT10 & Waves Ilok problem
Have you d/l'ed and installed the Pace interlock drivers from iLok as well as the interface stuff?
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 05-25-2013, 04:11 AM
Not sure of the exact drivers you're describing... but I downloaded the Ilok recommended software/drivers from their site, both the "client" software and the drivers. PT loaded other Pace drivers upon install. Did I miss something?
As I mentioned, PT worked fine... until I installed the Waves software.
Old 05-25-2013, 11:49 AM
RegenerationMix RegenerationMix is offline
Im not sure Waves version 6 will work with Pro tools 10 and windows 7. I am on Waves version 8 and its not even the current version.
Waves current version is 9.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 05-25-2013, 05:27 PM
Not sure whether it will be compatible, either.... I'll check now.
One way or the other, it's hard to imagine that Waves not being compatible would be enough to cause PT to fail to open all together. Frightening.
Old 05-26-2013, 04:20 PM
DetroitT's Avatar
DetroitT DetroitT is offline
FYI-Waves V9 Does work however. (In PT's 10)
And V-7 & 8
6.8 is going back a bit. I recall some waves installers needed a direct link from waves support Via FTP site. Drop them a line.
Old 05-27-2013, 02:45 PM
smfelton's Avatar
smfelton smfelton is offline
If you are installing the waves plugins last they may be overwriting the iLok drivers, install everything then install the latest iLok drivers last, see if that makes a difference.
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
iLok pairing problem PT10 reeve.pete Pro Tools 10 6 03-05-2013 03:34 AM
New version Waves 8.0.6 plus bass rider? ILOK site problem! crizdee Pro Tools TDM Systems (Mac) 7 09-28-2011 08:36 AM
Weird happenings ilok.com, Waves ilok, Waves forum crizdee Pro Tools TDM Systems (Mac) 6 07-16-2009 04:43 AM
waves version 6 and ilok problem Greene Pro Tools TDM Systems (Mac) 7 01-02-2009 05:41 AM
WAVES AND ILOK PROBLEM crizdee Pro Tools TDM Systems (Mac) 21 07-14-2008 01:31 PM
