A/D converter COMPLICATED
OK this is kind of complicated, I bought the Mbox2 because of its versatility but I wanna run an 8-channel mic preamp off of it. The problem is that because the Mbox2 has only spdif line compatability with it, I've found it almost impossible to find an 8-channel because they are all adat via lightpipe. I was wondering if there was a product out on the market that could convert a spdif line signal to adat. If there is one i need it. Does anyone know of anything that would do this for me or an 8 channel mic pre amp that runs spdif? Please help!
Re: A/D converter COMPLICATED
schlosse,
Welcome new user.. Quote:
If you need 8 external mic preamps feeding your PT system, you'd look at the 002. Or did I miss your Q ? good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
yah i have the mbox2 im looking for a converter if there is one out on the market that will change spdif into adat optical via lightpipe so I can run a really nice 8 channel mic preamp i can work this way and mic pre has to be adat( i like em like that)
if i keep the mbox than it's just more versatile and i can carry it around if i want to just mess around but pulling this off would basically turn the mbox into a tiny digi 002 and ssave me a ton of money in the future
The S/PDIF digital format is 2 channel only. Period. Any converters from S/Pdif to lightpipe would be converting for 2 channel lightpipe, not 8.
The MBOX2 is 4 inputs only. Period. 2 channels analog, and 2 channels S/Pdif. The only way to get 8 separate mic preamps to work with the MBOX2 would be to use a mixer and mix the 8 mic channels down to a stereo feed into the MBOX2.
I am missing something in your description..
Why do you need "spdif into adat optical via lightpipe" to use an external pre amp ?? There are many digital format converters on the market..but the type you are looking for will probably cost more than your Mbox. Nuendo, Euphonix come to mind. I use my TC Finalizer Plus for all kind of 2 channel conversion. good luck,
OK..I think I've figured out what you trying to do..
To use an 8 channel mic preamp to feed the Mbox like this : 8XADAT optical out>format converter>2channel SPDIF coax> Mbox digital in..Right ? this box would do it >> Or this one >> cheers,
are u sure cause there are crazy products out i think this could actually work but wouldnt be digital necessarily my main problem is wanting to record drums without mixing them before recording and this may work i dunno advice?
http://www.musiciansfriend.com/srs7/...se_pid/240312/ |
If you want to record into Pro Tools, you must use a digidesign interface. As I said earlier, the MBOX2 is 4 inputs, period.
The RME interface you linked to would be able to record into other software, and then you could import it into Pro Tools, but you would not be able to use it to record directly into Pro Tools. (you would also need mic preamps, and if you wanted more than 8 inputs, other interfaces) You WILL NOT BE ABLE TO record more than 4 channels at a time with the MBOX2. Period.
That is an IO unit (just like the 002) to facilitate inputs to a DAW OTHER THAN Pro Tools !!
There is NO WAY you can simultaneously record more than 4 channels of audio with your Mbox 2. Secondly..there is NO WAY that PT LE will be able to use any other hardware interface ! There is of course, the MPowered solution.. good luck,
Pro Tools too complicated | Slow Track | Getting Started | 48 | 02-19-2014 12:19 PM |
Why does activation have to be complicated? | marrowgroup | Getting Started | 26 | 01-21-2014 04:52 AM |
Help with complicated upgrade | marbleagle | Pro Tools TDM Systems (Win) | 1 | 11-08-2010 06:37 PM |
why its need to be so complicated???????? | A-ISH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-27-2007 11:26 PM |
Novice yet complicated 002r sync question | darkroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-10-2004 02:40 PM |
