External converters for 002r
Hello!
I need external converters for my 002r. I record tracks with my Mackie MDR recorder. After importing and editing into Pro Tools, I 'd like to run it back to my Ghost console for mixdown. So I just need 8 D/A converters. I need more than the 8 internal converters. I'd like to use 16 outputs from Pro Tools. Do you have any gear advice? I found lot of A/D converters but not D/A converters. Would the MOTU 2408 work just as converter? Thank you!! |
Re: External converters for 002r
Why?? And what is your budget ? If I was you, I'd just pump it back through the Mackie, as D/A good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Hello again!
I can spend 1000 bucks, not more. I use the plug ins and automation in Pro Tools. I don't like summing in the box. I want to use all my outboard gear as well. Running through the MDR would be an oppinion, but Mackie didn't answer me to the question: Can I use the MDR with analog card and the optical 24 card just as converter. If it works, I would buy the optical 24 card from Mackie. Thanks. |
AFAIK, the Mackie card slots are limited, but purchasing the optical option is IMO cheaper and sounds very good...Some of my clients use them, and was positively surprised on the DA quality.
Just pull and swap, as I remember... good luck,
External Converters Outside of PT? | JamLewis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-24-2009 09:00 PM |
Using external converters with 002 | Scot Stafford | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-11-2007 12:43 PM |
External AD converters and word clock for 002R | xlr231 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-01-2005 07:26 AM |
Alesis AI-3 Converters VS Digi 002R Converters | spicyitaliano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-19-2004 06:51 PM |
001 and External Converters? | evanb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-09-1999 05:19 PM |
