Old 10-29-2017, 12:16 PM
Southsidemusic's Avatar
Default Re: HDX with older Mac Pro
It is what a spell checker does to a mistyped resource fork.
Got it
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-29-2017, 12:18 PM
jre3132 jre3132 is offline
I am not sure what version of HDX you are talking about etc. Sone open with HDX running Pro Tools 10... if so the ones that don’t are possibly corrupted. When did they last work? On the exact same storage device? Were they moved? How over what filesystems? You got other session archives?
AFAIK Pro Tools 10 was the last version that supported reading SDII files. You don’t need HD hardware or HD software or even any external interface to just open a session then save and do the conversion from SDII audio files. We are talking Mac only here of course.
Having mangled or corrupt SDII files, especially because of missing audio forks is super common, so the first thing you want to do is just confirm you can open your original sessions/audio files OK in Pro Tools 10 or earlier.
You have to pay attention to running Pro Tools 10 on a compatible OS release. That might require you do a full clean OS X install.
Awesome. I was thinking I had to have hardware connected (whether it was a core card or an I/O. I thought I might could skate by on not having the I/O, but was pretty sure a card would be required for the software to start.
So in theory I can just install PT10 with no process cards and pop the ilok in to my old mac. Open the session and save the copy with the conversion to .wav and be good. That's great!!!
Thanks for the help. I was worried I sold my cards too quick. Somehow I missed all the info on SD2 files being phased out and not converted anymore.
Old 10-29-2017, 12:21 PM
Default HDX with older Mac Pro
You need to select “Built-In Output” as the playback engine, hold down ‘N’ when Pro Tools is starting.
You need to check before doing anything that the OS and Pro Tools 10 are compatible. And do not try to have multiple Pro Tools versions installed under one boot partition.
Be very careful moving around these sessions, you can lose resource forks just backing up to the wrong filesystem/device.
Old 10-29-2017, 12:24 PM
From PT9 and onwards you don't need any hardware from Avid connected in order to run PT. Of course it is always better with an interface but for mixing and editing and file conversions the internal sound cards works great. We do this on the road all the time withmacbook pro's and a few headphones and that is on songs thats released for big artists. Mastered afterwards of course by pros but mixed and edited pretty much on MBP's with 8 and 16GB ram.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 10-29-2017, 03:56 PM
If you get in a bind, I have an old G4 rig that runs 7.4LE and I keep it around just for converting older SD II sessions
Old 10-29-2017, 04:27 PM
Thanks Albee! I've been away from the forums for a while but you have always been awesome to help!
Old 10-29-2017, 04:28 PM
Thanks guys!! Great info. I appreciate all the help!! I'll have to dig out the "old" mac pro and give it a shot.
older i7 jgirv Getting Started 7 06-30-2017 05:22 AM
updating older PT LE on older Mac skfdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2013 01:03 PM
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
Best use for an older 867 G4 carlos2909 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-17-2004 07:41 AM
older AGP 400 mhz G4s RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-27-2001 09:14 PM
