Create Cross Fades Across Tracks?
I have split the dialogue for the two actors across two audio tracks. (That's because Ashley's voice is not as strong as Jordan's. So I've added gain to her track, while I've actually backed off the gain a bit on Jordan's track.)
I did splitting by razor cutting the boom track whenever the dialogue changed from Ashley to Jordan. And I moved Jordan's dialogue down one track. The result is a checkerboard looking pattern with no overlaps between the tracks. At each cut, I want cross fade between the end of Ashley's dialogue on Track 1 and the beginning of Jorndan's dialogue on Track 2. Is there a way to apply a crossfade across the two audio tracks? (Similar to how you would apply a cross fade if the dialogue were all on one track.) What I'm trying to avoid to do is manually extending Ashley and/or Jordan's clips by a few frames so they overlap and then adding a tail fade to the outgoing clip and a head fade to the incoming clip on the other track. Hope that makes sense. And thank you so much! |
Re: Create Cross Fades Across Tracks?
Why not go back to one track that has both and either use volume automation or clip gain to balance things out? That way you don't have to worry about cutting at zero crossings for one thing.
The best thing to do here is to edit your dialog correctly by creating appropriate fill before and after each line of dialog for each character so the edits are seamless. If you do a batch fade by selecting all clips what will most likely happen is you will either create a fade going into your spoken dialog, which is not preferred, or you will pull out the heads and tails of each clip with a fade which could contain the other character's dialog. This would mean you could potentially be doubling little parts each characters dialog on separate tracks which might produce minor bumps in the edit and make it challenging to mix.
Pro Tools 8.0.1 and Fades and Cross Fades Pop | mikejavo | Pro Tools TDM Systems (Mac) | 1 | 11-26-2009 08:54 AM |
create fades batch fades issue pt le | theom | Tips & Tricks | 4 | 07-24-2006 09:46 PM |
Multiple cross fades | Marcoma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-27-2005 07:32 AM |
Cross Fades | drumkid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-26-2005 10:30 PM |
Cross-fades between songs | Esteban | Pro Tools TDM Systems (Mac) | 5 | 03-04-2002 01:56 PM |
