Old 11-28-2015, 08:17 AM
PT8716 PT8716 is offline
Default Eleven Rack error message
I keep getting this message saying "Eleven Rack #2 has experienced an error. Would you like to re-connect?" I am running PT 11.3.1 I just did an un/reinstall. It seems to be working with PT 10 and the stand alone editor. Please see attached screenshot.
Old 11-28-2015, 08:39 AM
Default Re: Eleven Rack error message
Windows 10 Pro
Old 11-28-2015, 09:06 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
There is a utility called USBDEVIEW. It was first brought to our attention by guitardom.
USBDEVIEW windows utility Check it out. You can find and delete your old or duplicate 11R driver very easily with this.
Squaw Creek Road Studio
Bob
Pro Tools Standard (current version)| Avid Eleven Rack ERXP | Sibelius Ultimate (current version)
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Catalina |
Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack |
Old 11-28-2015, 09:28 AM
Benoni's Avatar
Benoni Benoni is offline
It's all covered right here
http://elevenrackusers.blogspot.com/...-part-1-2.html
Turn off the 11R. Uninstall the the driver. Check device manager and make sure everything that says Eleven Rack is gone.
Restart. Install the driver. Shut down. Turn on Eleven Rack. Turn on PC. Open Pro Tools, the problem is gone.
If you change the USB port you are using for the Eleven Rack the problem will reappear.
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
Old 11-28-2015, 09:43 AM
YYR123's Avatar
YYR123 YYR123 is offline
I thought this was just on Win/PC's? I had this start happening on my hackintosh the other day....
It works fine after the first dismissal
Daniel
Old 11-28-2015, 01:10 PM
Thanks Cowboy Bob & Benoni! It's working fine now.
Eleven Rack comunication error chrisdesherlia Eleven Rack 9 05-06-2014 12:46 PM
Error Message When Using Digi 002 Rack with Protools 9.0.6 warrioressx macOS 2 06-18-2012 02:32 PM
Eleven Rack Communication error filosofem Eleven Rack 16 12-24-2010 10:39 AM
Eleven Rack & PT8: constant -6101 CPU Error Message Hank Marvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-22-2010 12:03 PM
001 Rack -9129 Error Message gibson_rules63 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-29-2005 12:36 AM
