Old 06-26-2013, 02:56 PM
Roy Howell Roy Howell is offline
Default House burned down.....need some advice on replacing what I had...
Some of you guys may remember me from a few years back.....my house burned down recently including my studio stuff, etc......I am just now at a point dealing w/ insurance about replacing the studio part of it all.
The problem is, what I had was fairly dinosaur stuff, in that, I had an 002 Rack, which they don't even make anymore........I've been playing out live more in the last 5 years than when I was constantly recording before, so I'm unfamiliar with the newer Digi products out there.
Insurance is willing to upgrade me somewhat from the 002 since it's not even available, but I wanted to ask you guys' suggestions on where you would try and go next.
Also, I was using a Quad pc built just for ProTools, so I'm gonna replace that with a much better one.......and I was using a GreatRiver Pre, and an Apogee Rosetta AD/DA converter.......ALL of it was either destroyed by fire or drenched in water.
I need to submit this stuff to insurance now asap, and I would really appreciate your suggestions.............thanks, Roy
rh music
Old 06-26-2013, 03:32 PM
Default Re: House burned down.....need some advice on replacing what I had...
That's a tough road man. Sorry you have to deal with it. While there are several 3rd party options that cover the 002, I'll stick in a vote for the 003R(which can be found second hand for as little as $300, or new for around $600). This is not to say its the "best" interface out there("best" being a debatable term anyway), just that it offers a simplicity of integration with Pro Tools(I would have other recommendations if you were going with another DAW), sounds better than the 002(but you would find it very easy to use as you already know the 002), and adds wordclock, which makes clocking a bit easier(with the 003 as master, or as the slave). Adding a high-end light-pipe preamp bypasses the 003's converters(Focusrite ISA428 or UA 4-710D come to mind). BTW, both these options allow for adding 4 more channels of any brand external mic pre(in case you wanted another Great River). Some other options that would include some sort of monitor/input software to deal with: Focusrite Saffire LS56 and Pro40, MOTU 828 MkIII and anything from RME.
As for a new PC, if you are going to build; i7 socket 2011/x79 motherboard/quad-channel RAM is my preferred build. If you plan on buying an "off the shelf" PC, I would look at RAIN and http://www.pro-tools-pc.com/ or Sweetwater. While I am not a fan of the socket 1155 builds, these companies have it together enough to offer solid builds that should deliver.
I use an 003 controller everyday, along with a Focusrite ISA428, a lunchbox of preamps feeding the extra ISA A>D inputs(Neve and API clones), a DBX 386(via SPDIF) on an older i7 socket 1366 build(950 w/12GB of RAM) with Windows 7 x64 and PT10, and its a great little rig. I just wrapped a mix last week with 103 audio tracks!! (BTW, I also use a Focusrite OctoPre MK II Dynamic as my 8 analog inputs(modest improvement over the stock 003 preamps).
Old 06-26-2013, 04:23 PM
Thank you SO much, albee.....this gives me a good starting point on what to get.......I'm 2 months into this now, and just now able to focus on getting my studio back....been pretty devastating......I may be back for a little more advice, but definitely THANK you......-Roy
rh music
Old 06-26-2013, 04:29 PM
jryser's Avatar
jryser jryser is offline
Sorry for ur loss Roy - it's a reminder for me to film every bit of gear I own, which I will start doing this weekend.
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 06-26-2013, 07:17 PM
Thanks jryser...
rh music
Old 06-26-2013, 07:38 PM
sunburst79 sunburst79 is offline
A buddy's coming in from Memphis for a week around the fourth. I can send a 002 console back with him if you need to get some work done.
Needless to say I'm sorry about your loss.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 06-26-2013, 08:43 PM
The Weed's Avatar
The Weed The Weed is offline
Roy, tough road, so sorry to hear about the fire. Best of luck getting your studio back together.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 06-26-2013, 09:47 PM
Craig F Craig F is offline
003s not a bad choice but if they will buy new take a look at RME or Universal Audio's Apollo. Especially if you can get a PC with Thunderbolt.
Great River had a 500 series module option, I would try and get a 11 slot frame and some pres to start
Don't for get about your mics
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 06-27-2013, 04:15 PM
Thank you, guys, so much.....I've PM'd a couple of you......much appreciated.....-Roy
rh music
Need advice on the best pre-built PC for PT after my house burned down... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-24-2013 05:51 PM
Burned in TC bdangler Post - Surround - Video 7 09-10-2013 10:14 PM
Advice on replacing 002 rack soundmind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 06:56 PM
Have you ever burned? Orange Worker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-26-2004 08:51 PM
clipping when burned to CD johnmazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-27-2001 03:40 PM
