#51
Re: Audio Record or Playback Volume Error Info
When you say you've purchased an 'interface card' - what type of card is this? Is the drive connected directly to a FW port on the computer, or is it possibly connected to a FW card? Have you tried connecting the Mbox to a different USB port on the computer? After doing the update, have you tried trashing preferences and database files, or tried creating a new admin account and see if things work under the new account? When you say you haven't received a response from support, how did you contact support? Did you use the Tech Support Request Form? |
#52
You can download Stuffit at www.stuffit.com. |
#53
Thank You.
1. OS 10.4 (Retail version) directly as it came from the store. 2. The FW Card is a LaCie FireWire 800 PCI Card. The HD is connected directly into this card. The computer itself only has FW 400 ports. I had tried the FW 400 ports and same problems occured so I got the 800 to see if that improved the situation. 3. I tried multiple times to connect to every USB port in the computer, and even the peripherals, even though it was against recommendation. You never know sometimes. 4. I did trash the indicated files, tried a new admin account. Purchased a new HD and Installed the OS, PT Fresh, a couple of times, checked all permissions after each action on the HD. 5. I did use the tech request form, outlining the same as above, and previous post on 8/31/2005. My system is not connected to the internet, MAC G4 Sawtooth, 1 Gig mem. 400MHz processor, Maxtor 150 gig HD, and Seagate 120 Mg Internals, and a FW OWC 80 Gig external (for audio). Besides the LaCie card, there is an audiomedia III card inatalled as well. That about sums up the computer system. Thank you for your response. |
#54
Medbear - first, you have to remove the AMIII card from the computer. You can only have 1 Digidesign interface installed at any one time.
Once you've done that, see if you can launch Pro Tools and check that the drive is recognized and usable as a record volume. |
#55
Dear DigiTechSupt, Thank you...removing the AMIII card did the trick. Up and running with a good audio record drive. Thank you also for your patience with me and the others. It is really appreciated. |
#56
Thank you so much, that was the answer to the problem!
#57
EXTERNAL OR INTERNAL HARD DISK????
HELLO
MY EXTERNAL FIREWIRE HD COMITE SUICIDE. SO I PUT ANOTHER INTERNAL SEAGATE DISK OF 250GB. ITS OK THAT I USE ANOTHER INTERNAL DISK FOR MY SCRATCH DISK OR NOT? G5 2.0 DUAL ONE INTERNAL 160GB ONE INTERNAL 250GB DIGI 002 RACK PT 6.9.2 OSX 10.4.2 THANK YOU ADMIN LEO |
#58
Re: EXTERNAL OR INTERNAL HARD DISK????
Yes, this should work just fine.
#59
If I have to reformat, I will have huge problem, as I have approx. 30-40 Gigs of Audio on the drive, with no where to put it.
#60
workspace - audio record volume | juicytunes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-17-2010 03:33 PM |
"Session must be on an Audio record volume" - Workspace info | jojo101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-19-2007 05:07 PM |
"Session must be on an Audio Record volume" - Workspace info | DigiTechSupt | Pro Tools M-Powered (Mac) | 20 | 03-11-2007 06:23 PM |
Audio Record or Playback Volume Error Info | jarno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-12-2006 05:22 PM |
need help :workspace audio record volume | nicolas paris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-24-2004 05:51 PM |
