Old 01-11-2000, 06:27 PM
George Cumbee George Cumbee is offline
Default AIII Card won\'t recognize
Moved an AIII card from an 8500 to a 7200/120. Was working fine on the 8500. I reinstalled SDII 2.83 and PT 4.3.1. When I launch either it says "must have proper DSP card to run". Tried everything.
Tried all 3 slots.
Any Ideas?
7200/120 OS8.1 Digi init 2.94
George Cumbee, Pres.
Audio Creations Inc., Paducah, KY
Classic Recording, Franklin(Nashville), TN
www.classicrecording.com
Old 01-11-2000, 07:59 PM
Techsupt2 Techsupt2 is offline
Default Re: AIII Card won\'t recognize
When you install the v4.3.1 software make sure you've selected the AMIII install from the CDROM. It sounds like you've installed software for a TDM system.
Brad
Old 01-11-2000, 08:08 PM
Brad:
Had not actually run the 4.3 yet. I got the message first on the SDII 2.8.3 That is what I was wanting to use this machine for. The card had worked fine on the 8500.
Other than a PCI problem, any other ideas? We have a large PT/PC system, as you know. I just wanted this setup in another room. I may have to go back to the 8500. Wanted to use it elsewhere for an additional editor.
I have seen this hapen before on a Nubus machine. The dialog kept coming up as if I did not have a card in. Can't remember what cleared it.
Thanks for any advice and any ideas you have.
George
Mac Pro don't recognize HD Native PCIe card sc-30 Pro Tools HDX & HD Native Systems (Mac) 11 02-19-2014 12:40 AM
PT HD won't recognize my 192 i/o after installing an A/D expansion card riffmachine Pro Tools TDM Systems (Win) 2 12-21-2009 06:20 AM
PT won't recognize farm card dj_grimmace Pro Tools TDM Systems (Mac) 1 12-28-2004 12:24 PM
Can't recognize PCI card for Digi 001 - HELP!! stoopid1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-01-2003 04:31 AM
AIII drivers for OSX? dannepop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-01-2002 07:00 AM
