#21
Re: Shortcut To Disable All Plugins
Sorry BScout, my bad for using 'disable' when I meant deactivate. I'm sorry, I got it mixed up.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins Last edited by lesbrunn; 01-29-2018 at 06:45 PM. |
#22
Control-click does nothing, Alt-click does nothing (reserved for copy-drag, i guess), cmd-click bypasses the plugin you click, and ctrl-cmnd-click inactivates the plugin you click on. And I found one that I had forgot about; Shift-click forces the plugin window to open in, I guess, default position on screen, like top left. And the key equivalents mac/win I think goes like this: Shift = shift Control = control/start Apple/command = Windows/command Option = Alt Last edited by Ben Jenssen; 01-29-2018 at 02:16 PM. Reason: Shift-click was sensured. I guess I forgot the F. |
#23
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#24
Ok I'm on my windows system right now and this is what i found ! PT 18.1
Ctrl+Alt+Click = bypass the plugins that row horizontal in all tracks Win+Alt+Click = bypass all the plugins on the session . Depends what insert you click . it bypass all plugins below Shift+Win+Click = bypass all the plugins on that track . Depends what insert you click . it bypass all plugins below Ctrl+Win+Alt = Make inactive the plugins in that row horizontal in all tracks Didn't found any shortcut to make all the plugins inactive with the open session .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
#25
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins Last edited by lesbrunn; 01-29-2018 at 06:17 PM. |
#26
Hey guys, sorry about the wild goose chase. The shortcuts jeam25 posted are right, and I'm back to square one! There seems to be no shortcut to deactivate all plugins in an open session, though it can be done row after row. If Avid can do it for bypassing all plugins, why shouldn't it be possible for deactivating all plugins?
#27
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#28
Edit. It's the same. Thanks for this one!
#29
No problem my friend !
#30
Yes Shift+a do the same thing on the selected track .
Shortcut to Enable/Disable Plug-ins ??? | russrags | Windows | 2 | 01-09-2016 12:24 PM |
Any shortcut to enable/disable pre-roll in transport? | Zarabozo | Pro Tools 10 | 2 | 01-11-2014 01:21 AM |
Disable Tracks Shortcut | Jon_Atkinson | Pro Tools TDM Systems (Mac) | 3 | 11-03-2005 04:50 AM |
Is there a keybd shortcut for record disable? | curve666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-13-2004 10:44 AM |
