How to mix vocals with music better in 1 minute
How to mix vocals and music? This is probably one of the most frequently asked questions after "how to mix music in general." I'm sure that by using my little piece of advice you will surely take a step forward in quality of your next mixes.
So, to make it simple, the finished mix should be perceived as a layered instrument where each of the sounds is arranged in a way that it doesn’t impede the other ones. And of course, it should perform its main task too! So music serves as a base to the vocals, and it means that we need some procedures so that the music gives support to the voice, but does not clash with its basic frequencies. Mid-Side equalization is going to help us with this task. Send the mix instruments to a separate AUX bus. They can be either almost all of the elements, except the leading vocals, or the elected ones – as a rule, the main ones (Kick, Snare, Keys etc.) At the next stage place on the AUX bus any digital equalizer that operates in the Mid-Side mode. Use any equalizer that's convenient for you. Even a stock EQ, available in your DAW, can do this task. The main thing is a possibility of working with the EQ separately in the Mid and Side channels. Now all that is required is to make 1 to 3 cuts with bell EQ in the Mid channel in the upper mids (Q is 4 to 6, attenuation is about 1.5 to 3dB) to eliminate the conflict. Of course, the main source of conflict of frequencies with vocals is Snare (or Clap)! But when applied to all the other instruments of the mix, this trick will give exactly that subtle feeling of better separation of vocals and music in space. Apply this trick at the very beginning of your work with a project, and mixing vocals with music will be a lot easier! __________________ |
Re: How to mix vocals with music better in 1 minute
This is a joke right?
Music Plays over vocals? | Floz313 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-25-2015 06:06 PM |
How do I get my vocals to flow better with my music? | ice0-5 | Tips & Tricks | 7 | 04-05-2011 10:24 AM |
getting the vocals inside the music | wuskool | Tips & Tricks | 17 | 11-28-2006 03:32 PM |
Music minus Vocals | bassbuddy | General Discussion | 11 | 03-25-2005 01:44 PM |
Removing Vocals from Music | Samhein | Pro Tools TDM Systems (Mac) | 7 | 08-26-2002 11:48 AM |
