Old 01-22-2018, 09:15 AM
Franklin77 Franklin77 is offline
Default Eleven Rack Amp/Cab not showing up
Does anyone know why the amp/cab section is not showing up in Pro Tools 10?
It just started doing this the past week. It works fine in the standalone version of the Eleven Rack editor but in Pro Tools it has a weird symbol where the amp should be. And not matter what I do I can't get it to change.
Old 01-22-2018, 10:59 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack Amp/Cab not showing up
Here you go, wrote about this back in 2012
http://elevenrackusers.blogspot.com/...howing-in.html
Basically, the integrated editor is using UI files for the stock Eleven Rack. You have an upgraded Eleven Rack (ERXP) and the integrated editor does not have files to reference the new amps and effects. You can run the ERXP updater to fix this. Or I think 10.1 includes the updated files.
Or, just use the standalone editor even when Pro Tools is open.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-22-2018, 08:09 PM
Thanks but I tried it and it did not work. I already had the current firmware because I am also using it on a newer Mac with a newer os. That’s probably were the problem started. Since it has the new firmware.
Old 01-23-2018, 10:57 AM
Benoni's Avatar
You need to run the first part of the ERXP installer, not the firmware upgrade. The first part installs the updated files for display. Although, why not just use the Standalone editor when you want to use the editor?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-23-2018, 11:40 AM
You are right. I can just use the standalone editor.
But I did run the first part of the ERXP installer and it didn't fix it. And I didn't update my firmware because it was already updated to the current version when I setup PT 11 on another computer using the 11R.
Eleven Rack not showing up in Mac High Sierra 10.13.2 Daudiovan Eleven Rack 7 01-10-2018 06:02 PM
Eleven Rack not showing up in Pro Tools LE jazz4man Eleven Rack 20 11-22-2013 10:55 PM
Eleven Rack not showing under hardware or playback AdamAMM macOS 5 10-24-2011 03:27 PM
Eleven Rack not showing as input mac PT9? microstudio Eleven Rack 6 03-15-2011 09:15 PM
Eleven Rack Not Showing Up In PT9 GanB Windows 7 12-12-2010 08:03 PM
