temporary group for track-faders ?
does someone know how to build a temporary group for track-faders, like it is possible in Digital Performer or in Logic ?
frequently I want to move some faders together without the need to built a group for them In Logic or in DP you only have to select those tracks and move one of their faders resulting that the faders of the other selected tracks move also Thanks for any hints
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
Re: temporary group for track-faders ?
That would drive me insane if faders were grouped together in moves if only the tracks were selected.
In PT you need to make a group; I don't believe this example of a questionable feature exists! I can send a bunch of tracks to nominal, mute, solo by selecting the tracks and Shift-option or shift-s for solo, etc, but not ride faders without a group. If Digi were to implement this, there had better be a way to turn it off (you know, like a preference check box, hahaha). Easier to make a group and then de-activate or kill it later.
... but does it help the chorus? |
You could create a group called "Temp", and simply modify it each time you need to remove/add members.
IHTH
thanks for answering
but how circumstantially this is, to built a group only to make some faders moving together (probably it will be faster to move them one by one) why not allowing the shift-option command to do this with selected faders ?
I do this all the time with VCA faders.
Let's say I want to raise all vocals a bit. I'll highlight all the vocal tracks in the edit window (which selects them if you have that link button on) Then I'll create a group and name it temp. Then I'll make a VCA track and assign it to Temp. Make my moves, then delete the VCA and hit yes that I want to coalesce. Delete my group. Done.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
thanks kenny for your help
yes, there has a lot of work to be done only to move some faders together in the same direction ;-) as I told before, in DP or in Logic only one step is necessary to do selecting the tracks and (while holding dedicated keys) ... moving them - so intuitive and easy
ya, i'm gonna plus 1 this,
here's why... when importing audio or session data; regions and media only, faders default to zero. (actually, i'd be fine with a default to off) but since they come in up i've often wished you could use the 'ol shift option to drag em down, but of course that snaps em to zero. so if we could add a modifier to make a temp grp that would be swell. or not, e
ihatetyping |
yes, for me it´s a little like the missing 'new playlist' command, so essential for a smooth workflow that you cannot believe it´s not implented in a 20 years old daw
Bottom line...... When I move a fader in PT, I don't want it affecting anything but itself unless it BELONGS TO A GROUP. (without a VCA)
PTHD6 / C|24 Controller / Euphonix MC Mix Controller / PT v.10.2 Intel MacPro 2.8ghz Quad Xeon / 18gigs ram/ PE6R4 Expansion Chassis w/Core,4 accel,1 process card, 46" & 24" monitors Syn-g www.bulletsage.com |
but for me it´s something like ... if you don´t know it - you don´t miss it why has this to be so complicated if I only want to move some faders together ?
How to group Send Faders | ivan4217 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-03-2008 06:34 PM |
Group send faders in LE 7.3 | 4times4mil | Tips & Tricks | 2 | 12-14-2006 12:27 AM |
How do you Group AUX faders? | ndaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-10-2006 09:37 AM |
Group Master Faders? | andydadd | Pro Tools TDM Systems (Mac) | 4 | 12-23-2005 11:04 AM |
How do I UN-group my faders? | bH101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-03-2004 02:02 PM |
