Old 02-09-2017, 12:36 PM
MixedByDEE4 MixedByDEE4 is offline
Default Updating from PT 12.5 to 12.7 Causes SB Wavelab to Crash
I've opened a ticket with Avid tech support on this one. So far, no luck with a resolution.
I recently upgraded my system from PT12.5 to 12.7 and then Wavelab Pro 9.0.35 crashes every time I try and exit the program with an error stating CFnd.dll is the cause. Since PT10 and Wavelab 7, I've always kept both applications open when working on projects as I like to bounce back and forth for editing files. It's always worked flawlessly.
I decided to roll back to my previous Macrium Reflect image which was running with no errors and try and duplicate the upgrades to confirm the cause.
On my Win7/64 system running an Apollo 16 FW (Silver face), with PT 12.5, Wavelab 9.0.15 and UAD 8.6, all is well.
When I upgrade Wavelab to 9.0.35, no crashes.
When I upgrade Avid App Manager, no crashes.
When I upgrade iLok drivers, it asks to reboot, then still no crashes.
When I upgrade PT to 12.7 it asks to reboot. When I log in, I don't even launch PT yet, I only launch Wavelab and it crashes with the same error from CFnd.dll. Steinberg confirms that CFnd.dll can cause the issues without Pro Tools even running. This is the case here.
I've tried installing ASIO4ALL and disabled all other audio drivers on my system. Wavelab still crashes on exit.
I've updated my UAD software to 9.0. Wavelab still crashes.
It seems that I've reasonably isolated the issue to the PT12.7 upgrade.
Any ideas on how to resolve this?
Old 02-21-2018, 06:48 PM
David Longmuir's Avatar
David Longmuir David Longmuir is offline
Default Re: Updating from PT 12.5 to 12.7 Causes SB Wavelab to Crash
I am having the same problem but the affected program in my case is SCS (Show Cue System).
Looking around, I see that in addition to SCS and Wavelab, Vegas and Finale are also affected.
The workaround I am using at the moment is described here at the Finale Knowledge Base.
Hope this helps,
David
_________________________________________________
Lenovo 90G8009HAU (i7-7700, Nvidia K620, SSD: M.2 256GB, HHD: 2TB 7200, 16GB RAM),
Windows 10, PT 12.7.0 & Roland Octa-Capture
Old 02-21-2018, 07:56 PM
Thanks for that info!
Old 02-21-2018, 09:12 PM
No worries!
Updating Plan - Updating Billing address conundrum Cate_C Licensing & Accounts 0 03-26-2016 04:55 AM
Unusual Crash after Updating to PT11 pianolife macOS 0 12-19-2013 03:18 AM
Updating PACE drivers... before updating to 9.0.5 lanstrad Pro Tools 9 0 08-28-2011 07:37 PM
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng FuneralMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 11-16-2009 12:02 AM
Installed 32track le version, won't run with Reaktor crash crash crash Christian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2002 11:05 AM
