Solo not working
I have a number of drum tracks that are then sent to a drum bus that I created which then feed into a Submaster bus and finally to the Master L/R output.
When I press the solo on say the kick drum I cannot hear anything. When I release I hear the whole band no problems. I can adjust the bus levels and add effects with no problem but for some reason Pro Tools is not able to solo an individual instrument, not even solo a bus. I must be doing something wrong. Any advice appreciated. |
Re: Solo not working
You need to Solo-safe the bus master for the drums. Don't be afraid to crack open the manual(aka Help file)
And don't forget to solo safe any busses downstream from the drum bus master
I use PFL solo mode.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
If you use PFL solo, you aren't listening through the chain/bussing your mix is normally routed out. Something to keep in mind.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Solo isn't working right | legacygt777 | Pro Tools 10 | 6 | 04-03-2018 07:49 PM |
Solo bus not working after bus changes | Audioartist | Pro Tools HDX & HD Native Systems (Mac) | 0 | 05-28-2017 02:23 AM |
Solo Clear not working on S3 | jmkeane | Avid S1, S3, Dock and Control App | 3 | 10-09-2015 07:34 AM |
Fast track solo out of the box not working | yoplin | FireWire & USB Audio Interfaces (Mac) | 0 | 10-10-2014 04:18 PM |
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
