Problem w additional latency on instrument plug-in when triggering from a different
Hi, Its been a while since I posted..
Wondering if anyone can help me - I am getting additional latency when triggering an instrument plug-in from a different midi or instrument track. Let me explain: Lets say I create a stereo instrument track (lets call it - "track 1") and I insert a 'Mini Grand' piano plug in. Now when I press record on that track and trigger the instrument it has an acceptable latency. Now If I create another instrument track or Midi Track (lets call it - "track 2") and if I now trigger the inserted Mini Grand on 'track 1' from 'track 2' (by selecting the same instrument on the Midi selector pull down menu), I get an additional latency when triggering the same instrument, which is not an acceptable amount of latency. I can get around this by inserting another instrument on 'track 2' but I would like to just use one plug in instrument in this case and trigger it from 2 different tracks. Can anyone tell me why I am experiencing the additional latency when triggering the plug in instrument on track1 from track 2? Thanks in advance.
Pro Tools 2018.12.0 (64 bit version) on Windows 10 Home, PC: i9 12900K w 32 GB |
Re: Problem w additional latency on instrument plug-in when triggering from a differe
Have you tried using midi tracks for the additonal midi input(s)? That would be the "correct" way, I think. And use the Instrument part of the tracks to route the midi signal. (Select Instrument in the selector where you show/hide inserts, sends and so on.)
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
OP, one thread is enough. Now you’re going to have two seperate threads and answers for the same issue which is going to get confusing.
Can a mod merge these please? Sent from my iPhone using Tapatalk |
Its actually 2 different questions. Perhaps I should not have brought up this issue in the other thread.
Hmmm... probably splitting hairs at this point. The questions are VERY closely intertwined.
Like I said, I just think you’re making it harder to track answer to your issue. Your choice obviously. Sent from my iPhone using Tapatalk |
Yes I use additional midi tracks to trigger the Virtual Inst in the Instrument track. I just reloaded the same session I was using yesterday and now I am getting the same latency (or midi trigger response time; whatever the problem may have been..) regardless of whether I trigger it from the Instrument track or a separate midi/instrument track. So now I don't know what was the problem but this it happens pretty often.
Midi on Instrument Track not triggering Structure | Mark Hucks | Pro Tools 12 | 2 | 05-11-2017 04:44 PM |
Instrument track triggering wrong VI... (help me Obi-Wan...) | leftalive | Pro Tools 12 | 9 | 01-16-2017 04:16 PM |
PT 9 - "Minimize additional I/O latency" PROBLEM | elmodagansta | Windows | 2 | 04-27-2013 06:11 AM |
Need help with plug-in instrument latency problems | ScottFB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-21-2007 12:22 PM |
Audio Latency when using RTAS instrument plug-in | djwilmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-10-2004 09:23 AM |
