  #421
Old 01-16-2021, 04:23 PM
Default Re: Dark Theme in Pro Tools 2020.11
Originally Posted by climber View Post
FWIW I tried the latest edit to Dark Mode, which I really like BTW, but it messes up my Slate Raven setup. Just so you know. I have no idea why that would be... Oh well, the regular DM is still better than Classic IMNSHO.
I don't have access to a Raven so can't help there. Wouldn't want one anyways considering what some here have said about them after using one.
  #422
Old 01-17-2021, 06:25 AM
climber climber is offline
Well... It’s a great tool for me. I’d be lost without it.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
  #423
Old 01-17-2021, 08:06 AM
JingleDjango JingleDjango is offline
Just tried out the most recent txt posted by macsearcher above. I've switch back to classic because I'm straining to read the names of inserts in the Edit window. (Light Grey on slightly less Light Grey). However, I wanted to say thank you to the users who put the leg work in to figure this out and present another option.
  #424
Old 01-17-2021, 08:51 AM
Did you try my file version? I tried some of macsearcher's changes when I was working up my version and found some of his color changes just didn't work for me and were actually more unreadable. I think some of this boils down to a person's color sensitivity and what stands out for that person and maybe no one else.
Mine has white text on a grey background. If you drop me a regular email I'll send you the file I'm using if you want.
  #425
Old 01-17-2021, 09:02 AM
I didn't. I was skimming back through the thread to find it actually but found musicman's first. Shooting you an email through the forum util, thanks.
  #426
Old 01-17-2021, 09:37 AM
Can't do attachments through the forum. You need to email me at [email protected] with your regular email address.
  #427
Old 01-17-2021, 11:57 PM
Eric Lambert's Avatar
I'm using some of that code but the inserts are one thing I'd modified (or just didn't copy at all from macsearcher). I don't recall the colors I ended up with (perhaps blue) but they're easily legible now. I know it's not the radioactive green that had floated around in some places.
  #428
Old 01-19-2021, 09:02 AM
MLaudio MLaudio is offline
Im generally a dark mode fan but this may be the worse implementation I've seen. Two things that stick out to me right way are the insert colors (not enough difference between the lane and insert) and the highlighting of regions (especially when you have dozens of tracks). It can be difficult to tell when some regions are highlighted or not.
When an insert is open, the insert block is a light grey. This is how it should be permanently whether it's open or not. Has anyone here successfully made the inserts more legible? Id be curious to try. In its current state, classic is much clearer and easy to follow.
  #429
Old 01-19-2021, 11:31 AM
There are only 42 pages worth of discussion about it.
  #430
Old 01-19-2021, 01:56 PM
jameyz jameyz is offline
Dark mode UI Works great here with RAVEN and looks super cool, file a support ticket with Slate if you need help.
https://slatemediatechnology.zendesk...UI-Mode-macOS-
https://www.youtube.com/watch?v=rgW6kZhYwoE
"Dark" theme improvements in 2021.3 midnightrambler Pro Tools 19 04-04-2021 05:15 AM
How to change Pro Tools 12 to a Dark theme/skin Defier Pro Tools 12 7 03-26-2016 05:22 PM
Pro Tools 8 theme for Reaper? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-09-2010 07:51 AM
Pro tools theme song....! roijin Pro Tools TDM Systems (Mac) 2 11-27-2001 07:15 AM
