Digitest failure hd accel card
I Bought an hd core and an hd accel card on ebay and realized I had to buy the flex cable still but figured I would digitest them for now while Im waiting. The Core card tests fine and has no problems whatsoever but the accel card fails digitest. Is this because there is no core card present when I run the test or is the card just bad? I ran tests with only 1 card in at a time since it wont even let me run the test on both together without flex cable.
The failure is "Bus Master Test DSP A -- Failed -- Could not allocate memory for the test. Thanks in advance. |
Re: Digitest failure hd accel card
Sorry if I don't follow...
Did you already install the ribbon cable between the core and accel cards or have you already ordered it? Because if you don't have the cable between the cards, the test should fail.
And yes, I haven't gotten the ribbon cable yet, just testing the cards since I bought them on ebay and want to make sure they were both in working order so I can return if not. Thanks |
I have never even thought of testing a lone Accel card, but I would guess it won't pass without a Core card.
please send me the card and we can fix it and make sure you have it back as soon as the next day
Local drop offs can get them back same day if needed please contact us the address below
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Whenever Accel card is inserted, Digitest won't launch | Backlash | Pro Tools TDM Systems (Mac) | 8 | 03-02-2022 02:30 PM |
HD Accel card show up on 8.11 and 9.02 Digitest | makaroni | Pro Tools TDM Systems (Mac) | 1 | 06-09-2012 08:09 AM |
HD Accel card only initializes after DigiTest | RoofTopLuki | Pro Tools TDM Systems (Mac) | 2 | 05-31-2011 03:51 AM |
Dodgy Accel card failed Digitest ?? | Jonsos | Pro Tools TDM Systems (Win) | 6 | 04-26-2006 11:52 PM |
Digitest failure - HD2 Core card | GL | Pro Tools TDM Systems (Mac) | 5 | 01-14-2003 12:41 AM |
