I'm trying to set my windows sound settings so I can use the Digi 002(PT LE 8) for playback through windows. It seems there is no option listed under the sound settings...
Is there a way to enable this? a driver I need to get? an update or fix? Currently I have been plugging my laptop output into the "alt src" input and using my 002 that way to workaround the problem, but I would like to not have to do this... Ive seen other systems like the HD ones having the option to select it as a sound device in windows control panel sound settings. Can anyone help? Thanks, JayP |
There's the Wavedriver here:
http://archive.digidesign.com/download/wave/ It's supposed to allow you to play Windows media through a Digi device, but it's anyone's guess as to whether or not it will work. I've never gotten it to work with the 003 Rack+. Good luck!
Help Us Help You Chris __________________________________________________ Focusrite Liquid Saffire 56 TCE Studio Konnekt 48 PreSonus Digimax LT Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4 macOS Catalina 10.15.7 Pro Tools HD 2020.12.0 Last edited by cwsand; 12-08-2009 at 02:01 PM. Reason: I felt like it! |
That wavedriver (MME Helper) only works with XP and you didn't specify if you're on XP or Vista. Best bet is to use on-board soundcard for non-Pro Tools sounds and use the 002 as it was intended.
Yes I am on XP w/ SP 3.
![]() Quote:
Here's some pictures to help. (should I be able to select digi 002?) http://img54.imageshack.us/img54/1998/playback1.jpg http://img54.imageshack.us/img54/8007/playback2.jpg I will try the wavedrivers when I get home. Hopefully this works? |
Because Digi didn't intend for that 002 to be a "soundcard." It's a Pro Tools interface. Anything else that does work thru it is either courtesy or just plain luck. AND no matter WHAT you do, you won't get I-tunes or Quicktime playback thru it. Plus, the wavedriver is SINGLE client, which means only one program at a time can access it. That means, for instance, if you go on the web and try to get internet audio thru it, your browser will access the wavedriver and probably not let any OTHER web audio thru it. Trust me on this one. That laptop output into the alt input on your 002 is absolutely the hands-down preferred method for getting non-PT audio to your main monitors.
Bleh, that is lame. I guess I will continue to use the method I have been.
Why is it lame? One patch cable, you want reliable non PT audio, all you have to do is push a button. Seems pretty straightforward to me!
![]() Quote:
Brian Windows 10 Pro 64 Bit Pro Tools 2021 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
What's lame for me is that the analog out on my Gigabyte board is extremely noisy. I'm either going to have to get a digital/analog converter and come out of the s/pdif out to the Aux In on the 003, or buy a new sound card - but none of this is Digi's fault. An additional s/pdif In for the Aux In would be nice though!
Help Us Help You Chris __________________________________________________ Focusrite Liquid Saffire 56 TCE Studio Konnekt 48 PreSonus Digimax LT Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4 macOS Catalina 10.15.7 Pro Tools HD 2020.12.0 |
Mbox2 MINI control panel not showing up | Adwel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-26-2011 06:34 AM |
Mbox2 audio / midi not showing in windows control panel | kavs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-26-2008 07:26 PM |
missing output option under Control Panel | bross | Pro Tools TDM Systems (Mac) | 3 | 07-25-2001 04:07 PM |
Digi Settings in Control Panel | JPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-19-2001 02:23 PM |
2930 setup and control panel settings | utopian | Storage Subsystems | 1 | 04-24-1999 09:59 AM |
