Old 11-13-2010, 10:33 AM
SixChurchStreet SixChurchStreet is offline
Default Apogee One, anyone using it yet?
Has anyone used the Apogee One with Pro Tools 9 yet? I'm curious as to the latency as compared to the usual fair firewire devices. Also, how low a buffer setting is available?
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM El Capitan | 2011 MacBook Pro 2.0GHz 4-Core i7 8GB RAM El Capitan | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2018 | Studio One 3.5
Old 11-14-2010, 12:05 AM
Ginger Ginger is offline
Default Re: Apogee One, anyone using it yet?
Bumping cause I'd like to know too!
TIA
Old 11-14-2010, 05:51 AM
producerdna producerdna is offline
I'm using PT9 with Apogee One on New MB Air(2.13ghz 256GBSSD 4GB Ram)..
I totally love it..
I usually put it on 128 but you could go down to 64 if you want..
I've set the playback engine @ 256 and I've tracked a lot of vocals
and it works great.. Definitely recommended..
Old 11-20-2010, 12:29 AM
stefaniscovolo stefaniscovolo is offline
producerdna....please tell me if you had a problem when you first started using apogee ONE with protools 9. I went to record vocals and I chose input 1 as usual and it said "no active unputs or outputs are set". I read online and had to create a new path in the i/o settings and then it worked but it sounds low and more muffled than when I use ONE in logic. How did you avoid that? Please tell me asap! I woudl love to know please. :)
Old 11-29-2010, 04:01 PM
I've had same problem so I got the answer from Apogee Support..
follow the instruction below..
Try creating a new Pro Tools session. On the new session dialog box choose Stereo Mix instead of Last Used for the I/O Settings dropdown menu.
Then do this..
Using PT9 with Apogee One
Apogee ONE is a single channel input Core Audio device. To gain access to ONE's input in Pro Tools 9, it's necessary to delete the default stereo input path and create a mono input path (in PT's I/O setup window)
1. Install Apogee ONE software and verify operation with iTunes and/or Garageband.
2. Connect ONE to your Mac via USB.
3. Open PT9 and choose Setup>Playback Engine.
4. Select ONE in the Current Engine drop down menu.
5. Click OK to close the Playback Engine window.
6. Choose Setup> I/O
7. Choose the input tab.
8. Option select all paths in the left hand column and click Delete Path.
9. Click NEW PATH, then name it promptly.
10. Click on the Routing square under ONE to assign the software path to One's input.
11. Click OK to close the I/O window.
[IMG] code is Off
Apogee Rosetta 200 (MINT), Lynx AES16e-SRC, Apogee Duet, BBE 882i, OFFERS ENTERTAINED jrhager84 Buy & Sell 5 03-11-2013 01:25 AM
DIGI 003 + Apogee Ensemble + Apogee Big Ben = World Clock marcioguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2011 02:24 PM
Apogee AD16X 192 help Apogee not seen in hardware manager assemblyworker Pro Tools TDM Systems (Mac) 4 04-19-2007 02:20 AM
APOGEE? volume9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-26-2006 01:32 PM
Apogee AD-16X and 001? Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-11-2005 02:27 AM
