Old 12-28-2019, 07:40 PM
sjgam sjgam is offline
Default S1 and Control App - I see the non-responsive Channel state on Sweetwater Demo
Noticed on the SweetWater S1 Demo on their site - https://www.sweetwater.com/store/det...ontrol-surface
It occurs at 8 min 16 second mark.
It's a weird bug in Channel Mode where some of the Channel features are unresponsive and the Channel Mode names are displayed in the center of the Control App on iPad sitting on the S1.
This is the same thing I am getting every few minutes in Logic Pro X mostly when using Config in Channel Mode. Here is my post describing it with exact same picture as Sweetwater Demo - http://duc.avid.com/showthread.php?t=407793
I thought it was something specific to Logic but in their demo they are using Pro Tools.
Can someone at Avid confirm they are seeing this and confirm status/plan of action as it makes it unusable if you have to keep restarting project or Eucon when you use Config in Channel mode.
I would think the odd display of the Channel Mode Names in center of screen may be indicative of what the software is incorrectly doing.
In my case in Logic - and in Sweetwater's demo case - Pro Tools.
Old 12-30-2019, 12:24 PM
EddieJones's Avatar
Default Re: S1 and Control App - I see the non-responsive Channel state on Sweetwater Demo
Are you talking about the function blocks in the middle of the screen that are blacked out ? If so are you sure the selected track actually has something for those blocks ?
Old 12-30-2019, 12:50 PM
Yes the function blocks in the middle of the screen and they are not all blacked out. All of a sudden the top left block displays the channel mode names themselves - inserts, inputs, eq, dyn, sends, mix etc. - and some of the channel functions become non-responsive. Press insert nothing happens etc. The top right and bottom two function blocks are blacked out.
Again look closely, you can see it on the screenshot of the Sweetwater demo I attached - which is kind of funny because if he stopped and pressed inserts or the function blocks he would get no response and you can see it on my screenshot I attached with me running Logic. Sweetwater is running PT.
Again the fact that it is displaying the channel mode names in top left function block when it goes non responsive might be a clue of what the software is mistakenly trying to do.
Again restart project or eucontrol and all works for a while.
Old 12-30-2019, 02:08 PM
Reattaching the two screenshots so you can see - both the Sweetwater one and my one in Logic - look to top left function block in middle of iPad screen.
Old 02-04-2020, 01:07 PM
Eddie were you able to reproduce the frozen state in channel mode on Control, S1 and Dock ipad where the function blocks on center all of sudden just display the name of the channel mode names and screen is not responsive. Again per the attached screenshots it happens in my case in Logic and in Sweetwater demo on their site in ProTools.
Here is my summary from before below referencing attachments
Old 02-04-2020, 07:28 PM
mattrixx mattrixx is offline
I am also seeing this behaviour. ..and yes, restarting Eucon, seems to fix it for a while.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 02-04-2020, 07:46 PM
EddieJones's Avatar
I've been playing with my App for a while and can't get it into this state yet. It must be a certain set of commands in a particular order that causes it.
Old 02-04-2020, 07:48 PM
Yes, you have to be right Eddie. It directly correlates to Channel / configuration modes in both the S3 and Dock in my case.
Matt McKenzie-Smith
mattrixx.net
Old 02-04-2020, 08:07 PM
EddieJones's Avatar
I wonder if its not caused by doing anything on the App, but by the attention that happens somewhere else and causes the app to respond...sometimes getting it out of wack. We have fixed a few things around this area for this upcoming release so hopefully.....
Old 02-04-2020, 08:10 PM
Mmmm, yeah, that sounds completely plausible. I'll have a bit more of a play around.. particularly with the S3, given it's behaving like the dock in a way.
Matt McKenzie-Smith
mattrixx.net
Channel State of Multi-Mono Plug-in epm AAX Plug-ins 2 02-01-2018 07:45 AM
AVID HD PRE DEMO sale.. sweetwater bacchus40 Pro Tools 10 0 06-29-2012 03:31 PM
002 Control Surface Non-Responsive on new PT9 Install Glitch Magnet Windows 8 05-22-2011 05:42 PM
SYNC STATE / MACHINE CONTROL FONT SIZE - feature request MIKEROPHONICS Post - Surround - Video 0 03-26-2010 02:03 PM
NEW-Waves- Solid State Logic E Channel & G Buss Stompinmsc Pro Tools TDM Systems (Mac) 89 02-09-2006 09:55 PM
