Old 02-02-2009, 10:06 PM
maharzan maharzan is offline
Default FW800 port —> FW800 Drive —> Out FW400 port on Drive —> Pro Tools LE FireWire
I need help in buying external hard drive.
from doc on digidesign, its stated:
*The late 2008 and early 2009 “unibody” MacBook Pro models require an unconventional configuration due to a lack of a FireWire 400 port and only having FireWire 800 instead:
MacBook Pro Tech Specs
The configuration options are:
1) FW800 port —> FW800 Drive (912 or 924 chipset) —> Out FW400 port on Drive —> Pro Tools LE FireWire audio interface
So, can anyone suggest me a good FW800 Drive? perhaps 500GB one.
Thanks for your help.
Old 02-03-2009, 07:03 AM
On Purnt On Purnt is offline
Default Re: FW800 port —> FW800 Drive —> Out FW400 port on Drive —> Pro Tools LE FireWire
I'm not 100% positive the firewire path will work (really I have no idea, it could work just fine) but LaCie Externals have been great for me so far...I bought a 200gb in 2003 that I still use cus it has a triple interface on it exactly like what you're looking for (USB 2, FW400 & FW800).
I would just verify whether or not the FW800 terminals on the hard drive enclosure allow you daisy chain using the FW400 terminal.
Good luck
-d
Mac Pro 2.8Ghz 8-Core
6GB RAM
OSX 10.6.6
M-Audio Lightbridge - PT9
Music Production Tookit 2
Old 02-03-2009, 07:30 AM
JrummerJ JrummerJ is offline
I was under the impression that it is not recommended to mix 400 and 800 devices on the MBPs onboard ports. So, I wouldn't chain an 800 drive with a 400 interface. An expresscard is probably your best bet, that is what I use. I have my interface connected via 6 pin firewire to the siig 400 card, and then my external drive is connected to the 800 port on the MBP. Puts everything on separate busses.
Great Drive: http://eshop.macsales.com/item/Other.../MEAQ7500GB16/
J
Old 02-03-2009, 08:37 AM
The Dougfather The Dougfather is offline
You need to downstep from the MBP to FW400 with a FW800>FW400 conversion cable, whis will bring the bus down to FW400 speed.
Don't mix FW's, alternatively use an xpress card as stated above.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
FW800 port on new MacBook Pro Soma Spiral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-17-2009 10:30 AM
FW400 HD on FW800 port? toddw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-17-2009 08:49 AM
MBP - 1 FW800 port. Need more than one Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-22-2009 08:48 PM
my fw drive only has one fw400 port Bryan Cook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-06-2006 12:21 PM
FW800 drive in FW400 mode okay? auxsend1 Pro Tools TDM Systems (Mac) 4 10-29-2004 03:27 AM
