Needing more I/O...Lynx??
I'm running PT HD 8.1 on a HD 2 system using a Digi 192 analog with 8 I/O.
I'm starting to mix and need more I/O to connect outboard gear so I want to hook up an Aurora Lynx 8 to the Digi for a total of 16 I/O. Is this possible? How would I connect the two and set this up in PT? Will I need any Lynx cards or addition hardware? Thanks in advance for the help. Rich |
Re: Needing more I/O...Lynx??
If you are going with Lynx, I'd suggest the LT-HD card. Pro Tools will see it as a Digi 192 and it will connect directly to the other HD card in your computer.
https://www.thirdeyerecording.com/ |
After doing some research I have been looking into getting the Avid HD i/o 8/8. I don't want to upgrade to the HDX since I'm happy with my current HD system.
Will the Avid HD i/o work with an old HD PCI-X core card? I would like to have the Avid run to the core card then slave the Digi 192 to the Avid via SPIDF... Any other way I should do this that would be better? Thanks!!!!!! Rich |
Just Needing Help | BDA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-08-2010 01:05 AM |
Needing your help | Thegenni | Pro Tools TDM Systems (Mac) | 0 | 02-18-2007 01:55 PM |
Mac Questions needing Help | mix_master_adam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-01-2005 04:16 PM |
new guy needing help | MikeSoloway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2004 07:49 PM |
Needing some insight... | BPhill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-05-2003 11:53 AM |
