Old 10-04-2015, 02:20 PM
ReynaldoPena ReynaldoPena is offline
Default Studio Monitors
Hello everyone,
I use Pro Tools 11 In my win 10 Toshiba i7, 12gb Ram laptop. About to purchase one of these affordable monitors deals. Although they may not sound as good as the expensive models. Which do you suggest from these two:
http://www.bhphotovideo.com/bnh/cont...Y&A=details&Q=
Or
http://www.buya.com/Item/Details/JBL...FcaPHwodYWwOEw
If you've got an idea of some good deals under 70-90 USD, I'd be appreciate it if you share.
^RP
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 10-04-2015, 02:26 PM
john1192 john1192 is offline
Default Re: Studio Monitors
Originally Posted by ReynaldoPena View Post
Hello everyone,
Or
^RP
ummmm .. the JBL's - One Speaker and a Sub - Really not what you need !!! well, if this is true than forget this one, not stereo .. that is one mono speaker and one mono subwoofer ...
the B&H speakers are USB ... You Did Not Say What Audio Interface you Use with Pro Tools .. ??? that will help make your decision - maybe you are not recording but just mixing so no Input is needed - Such Using USB Speakers ... just thinking out loud ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-04-2015, 02:40 PM
cheers john
John, yeah I use the M-audio fast track interface. My bad, are you saying the USB choice is the way to go? Many thanks.
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 10-04-2015, 03:41 PM
No a USB anything is the last thing you want. You need monitors that can connect directly to the outputs on your interface.
At this price range you are likely wasting your time. I would put that money towards a pair of headphones instead.
Old 10-04-2015, 03:44 PM
so they would use those two ports I'm I right?
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 10-04-2015, 03:59 PM
Bookerv12 Bookerv12 is offline
Darryl is correct as he usually is.
(I'm sure he's been incorrect before, but I can't find it)
Buying terrible speakers is a bad idea.
Having said that, if you realize that you will not be doing critical monitoring, these are OK, especially if you want more than one person to listen at once:
http://www.amazon.com/Mackie-CR-CR3-...3999184&sr=1-1
All you need is a pair of RCA cables and a pair of speaker cables and you are good to go. (The amp is built into one speaker.)
Good luck.
bookerv12
Craig F Craig F is offline
M Audio 5s or 8s. they have issues but they are workable
Then save enough to buy a new car and buy a pair of Focal SM9s
Thank you,
Craig
Old 10-04-2015, 04:02 PM
Drew Mazurek's Avatar
If you need/want speakers, buy speakers. I'd recommend NOT getting used to working with headphones for critical listening/mixing. Not as your primary device anyway.
www.drewmazurek.com
Old 10-04-2015, 05:34 PM
albee1952 albee1952 is online now
If you are serious about recording, you need better speakers, and you need a better interface. And as said, you can't use USB speakers WITH any interface on a Windows PC(the speakers NEED to connect to the interface). My 'best cheap" speakers are the JBL LSR305's. Shop used, or build a relationship with the local GC Pro person and you should be able to buy a set for around $200(and they kill everything else in that price range). As for a better interface, I would shop for a used Mbox 3rd gen.
Last thing to keep in mind, no matter what speakers you buy, they will be affected(for better or for worse) by the room you place them in(and where in the room). This is a lesson we all learn the hard way(right now I am dealing with a $3000 set of Genelecs that sound bad in my new control room) More bass traps...more diffusers....MORE POWER, Scotty!!
What Studio Monitors are you using dream5695 General Discussion 39 12-22-2013 11:56 AM
Studio monitors ps5user Pro Tools M-Powered (Win) 7 09-26-2010 02:46 PM
Make Studio Monitors as Desktop Monitors through Mbox2 ???? dcwang3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-17-2007 08:02 AM
Studio Monitors gustavof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-10-2004 09:27 AM
Studio monitors Haraldur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-27-2004 11:38 AM
