#391
Re: My Build and Questions
#392
Once, I figure out these fan options I think that will just about do it for my configuration and I can finalize my system and order it once and for all! I cant wait to get this system built and do some dverb testing . |
#393
I'm not sure which Noctua would be best. I will have to hit www.silentpcreview again and see what the differance is in CFM between the 2. It may be something that needs to be determined in in your case. You would certainly be safe with ordering the higher speed Noctua and using it for either the CPU fan or the case intake. That way if you needed more airflow more you could move the Tricool to the CPU cooler. Also let me double check with Vocal VooDoo and make sure he's running the Thermalright Ultra 120 Extreme in the 180.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#394
#395
Previously I had a Scythe Ninja REV2 which was quiet as hell, but didn't cool quite as well as the Thermalright Ultra-120 Extreme. It did keep my B2 stepping Q6600 within safe operating ranges though. But overclocking the CPU would heat things up pretty bad. The Thermalright seems to work better under the duress of OCing. |
#396
Also, what kind of fans are you using in your case Vocalvoodoo? Thanks in advanced! |
#397
I see Josh stopped in I talked to him earlier and I got the inpression he would recommend the Scyth Ninja (RevB?) first over the Ultra 120 Extreme. I'm not sure that flipping the cooler 180 degrees is going to make much of a differance... No matter what way the coolers positioned its going to be X amount of weight hanging off 4 tiny screws. Unless your over clocking the Ninja's should be fine plus you should be getting the cooler running G0 stepping series processer at this point in time. As far as the sag goes the only thing that's going to cure that would be laying it down like a rack case.
Newegg has apparently discontinued the Ninja Cooler. You can find it here A review of 120mm fans and another here. Heres a review on the Antec 182P case The Ultra 120 Extreme cleared all of the stuff on my Mobo (heatsinks, caps etc), so does the Zalman CXPNS 9700. I can't say for sure that the Ninja will fit since I haven't tried one. It probably will and In a month or so I will probably try one. Also the last 25-30% of my rack case is made out of perforated steel and any CPU fan noise comes right out the top of the case. With the Antec being enclosed I'm willing to bet that you would find the Zalman to be very quiet.
#398
------------- Antec P182 Gun Metal Black 0.8mm cold rolled steel ATX Mid Tower Computer Case - Retail $149.99 CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail $124.99 Quiet Case Fans - Noctua NF-S12-800RPM 8 dB 120mm Case Fan $19.75 ea. X3 = $59.25 ASUS P5K DELUXE/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard - Retail - $209.99 Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail - $279.99 Quiet CPU Fans - Intel - Scythe Ninja Plus B Quiet CPU Cooler with Fanless Option or Replaceable Fan - $44.95 SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N - OEM – $35.99 ASUS EAX1600PRO SILENT/TD/256M Radeon X1600PRO 256MB 128-bit GDDR2 PCI Express x16 CrossFire Supported Video Card – Retail - $66.99 CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory – Retail - $119 X 2 = $238.00 - ($15X2 Mailin Rebate) 2X Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive – OEM - $84.99 (System) (Audio) Seagate Barracuda 7200.10 ST3750640AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM Backups - $194.99 ------------------------ Now the only thing I'm wondering is whether or not the ninja will need a fan and whether or not the 3 800rpm noctuas will cool the entire case? Any last minute ideas? |
#399
Asumimg the build goes well I will add the case, cooler e and the fans to the Spec page as optional components. Drop me a email if you needs help with the build. Last thing pick up a tube of Arctic Silver thermal paste for the heat sink.
#400
Well, I'd probably but the Thermaltake again because I'm an overclock dork and can't stop. But for normal CPU clocking, I'd probably not get it again. Especially with the new G0 stepping as Sun mentioned. My Q6600 seems to run pretty hot though because it is a B2 stepping version.
The fans I'm running now are the Scythe NMB fans on both the back and top of the case and one of the 3 way switch fans that came with the case on the heatsink itself. When recording, I'll clock the case fans down with speedfan and switch the CPU fan to the lowest setting. I rarely use it anymore, but if you want specific temps, let me know and I'll fire it up. I will say this, I was much happier with my e6600. Ran much cooler, and I only ran the fan that came with the Ninja, no case fans, and things stayed more than cool enough. I could hardly hear the fan running. |
i7 Builds - Specs and Results | mykhal c | Windows | 7136 | 03-06-2024 09:04 AM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
