Re: Problems with volume faders in D Command
Update...
Frogging around behind the DCommand, I found that unplugging ALL 6 of the audio connectors on the JBL sub solved the problem of faders/rotaries not responding to touch. Any one of the 6 connectors (3 in, 3 out) brings back the trouble when connected. Since this is obviously not an acceptable solution, I tried just lifting the ground on both AC connections for the DCommand. Bingo...trouble goes away. Kinda' wish I'd tried that right off the bat. (Always looking for the complicated solution first, I guess) So, the long-term plan here will be to run a separate ground rod outside the studio, and throw a grounding bar behind the DCommand so it will be all by its little ol' self to Earth. Symptom gone, but I don't consider this 'solved.' No other gear in the place complains about the power. Sens-si-tive! |
FS: D-Command ES 24 Faders / like new | Numarek | Buy & Sell | 0 | 04-30-2013 06:12 AM |
Command 8 - more than 8 faders? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-08-2012 08:05 AM |
D-Command... faders only possible? | Hardin | ICON & C|24 | 2 | 11-21-2011 01:58 PM |
Command 8 faders affect input volume? | tapani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-28-2004 01:26 PM |
002 and Command 8 faders (not together) | Bixby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-22-2004 08:17 PM |
