Old 06-01-2012, 01:56 AM
RobeEQD RobeEQD is offline
Default Dead Faders on Control 24 :( Help Please!!
I bought a Digidesign Control 24 on Ebay. When I tested, everything works fine except faders. I put the control 24 on vegas mode and nothing happen.
Ethernet conection is ok, transport is ok, peak meters ok, but faders are not working. Can you help me please
Old 06-03-2012, 03:07 AM
Default Re: Dead Faders on Control 24 :( Help Please!!
Can somebody help me please?? I dont know what to do
Old 06-08-2012, 11:11 PM
crizdee's Avatar
crizdee crizdee is offline
Turn upside down (on a soft surface) remove all the screws holding the base on, till you an remove the base away from the unit. Now yo can see all the connections to the fader boards!
There are 3 fader boards! Each board has 2 connections. Check all the connectors are fitted correctly!
Also check all the connectins to the power supply on the back of the unit. There are about 12+ screws holding the PSU in, once screws are removed you can gently move the PSU slightly out of the unit! Label all the connections so you know which connections go where etc. then remove one connector at a time and clean with switch cleaner then make sure to fit back tight.
If its not the connections inside the unit, then you'll need to get it sent to a repair center.
Chris
Producer, Engineer,
www.ukmastering.com
Dead Faders engininja Artist Series 3 02-14-2012 10:01 PM
D-Control faders all dead Mikey MTC ICON & C|24 5 01-11-2012 04:02 AM
All Faders Dead......? BaileyBass ICON & C|24 3 03-20-2011 09:10 AM
dead, non responsive faders steviecandtheplacetobe ICON & C|24 6 01-17-2011 04:40 PM
003 Faders are dead ostrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-10-2008 07:19 PM
