Old 10-23-2020, 01:16 AM
DannyVanSpreuwel DannyVanSpreuwel is offline
Default Does an eGPU help a large session?
My setup:
Computer:
Mac mini 2018 i7 6-core.
Displays:
TV LG 4k (video playback)
UltraWide 32 inch (main)
HD 1080p (secondary)
I noticed that the CPU is pushed to the limit now. Occasionally the systems stops because of the CPU overload. Video is played on a third display. Before I used a BlackMagic Ultrastudio mini monitor as the video hardware output. It felt that it helped the CPU load. Now with the third display it's on the edge. Does an eGPU helps to lower the CPU load? The internal Intel video chip (activity monitor) doesn't work as hard as I would expect. Hence the question about the eGPU.
Thanks in advance.
www.protoolsles.nl
Old 10-23-2020, 02:19 AM
Default Re: Does an eGPU help a large session?
I doubt it will make much difference to CPU use. All that screen real estate is causing the CPU to do a lot more processing.
MBP 2015 with eGPU to Help GUI Lag tomaspal macOS 2 04-07-2020 12:24 PM
MAC Mini 2018 with eGPU 11miles Pro Tools 12 0 12-18-2019 12:45 AM
Large session will not open in MP9? NeveSSL Pro Tools M-Powered (Win) 1 01-06-2012 04:38 PM
cutting up large session RobN Tips & Tricks 2 12-05-2005 05:46 PM
Can't Open large 4.3.2 session in 5.0 Stratman Pro Tools TDM Systems (Mac) 9 02-02-2000 11:21 AM
