Ultimate PC for 001...
Hey guys, I'm building a system for a friend who will be using the machine primarily for audio. I've built PCs in the past, but I'm not quite up to date with what's hot right now and working with PT. The budget is big, but we don't want to get rediculous. If you guys could let me know what hot mobo/cpu combos are working with PT right now that'd be great. Thanks a lot.
-Dave |
Re: Ultimate PC for 001...
Asus A7M266
AMD Athlon XP 1900+ (1.6GHz Relative performance) Thermalright SK6 Copper Heatsink Matrox G450 32MB DDR Dual Head Promise Ultra 100TX2 IBM 60GXP Hard Drives Enermax or Antec 350watt Powersupplies and a well ventelated sturdy chassis should do the trick. Hope this helps. Regards, Alex T.
Alex www.dreamware.ca Have something to brag about...Own a Dreamware Audio PC... My Rig: AMD Athlon XP 1700+ 512MB PC2700C2 Corsair MSI KT3ULTRA ARU 2x 80GB Seagate Barracuda 4 in RAID 0 GeForce 2 Ti 64MB Lite-On 40x12x40 CD-RW 16x Pioneer DVD Intel Pro/100 + SB Audigy Digi 001 |
Alex,
Thanks for the reply. That helps a great deal. Are you running this system? -Dave |
Hey Alex, Have you run the torture test on that set up yet? I have the same mb and want to upgrade. How much better than a 1.4 tbird?
I have been delaying the results for several weeks now, but hope to have them soon. Patience my friends...
Regards, Alex T.
Hi everybody! I'm about to build a new PC to be used with 001; This is the config I was thinking about; does anybody has info on how this components work togheter and with 001?
INTEL PIII 1GHz Asus TUSLC Motherboard Quantum Fireball Plus AS ATA 100 Boot disk Quantum Fireball Plus AS ATA 100 Audio Disk 512 Mb Dimm RAM Also, What about a SCSI Controller, any advice? Thanks a lot !! |
Without doubt, go with an AMD based system instead of the PIII. You will save $ and get A LOT more performance. There is tons of info in this forum about this issue.
Musician/Electrical Engineer San Diego, CA |
check out www.dawbox.com for more info on this....
Killer System:
The new A7V266E with KT266a chipset and the new XP 1.9Ghz processor. KT266a chipset is the best Athlon chipset available now surpassing the KT133a, AMD761 and KT266. Check out review at www.tomshardware.com Has onboard Promise ATA controller already. Great looking board and proven with Digi001. Allen [img]images/icons/smile.gif[/img] |
with support for windows XP coming out I would seriously consider going for a p4 and build a system for 'the not too distant future' so you won't have to upgrade anything too soon.
Win XP is a way cool operating system (the most stable yet in my opinion) and as soon as digidesign support it, it'll rock. [img]images/icons/wink.gif[/img]
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Should I get Win 7 Pro or Ultimate? | miek07 | Windows | 4 | 01-05-2013 04:43 AM |
PT9 compatible with WIN 7 Ultimate? | on tilt | Pro Tools 9 | 3 | 11-09-2010 08:57 PM |
Vista Ultimate 64 (the ultimate dissapointment) | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2009 04:44 AM |
The Ultimate Reverb! | bassmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-25-2001 10:17 PM |
Yes! The ultimate front end to the 001!!! | Dean Bohana | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 37 | 03-05-2001 07:41 PM |
