Old 07-27-2020, 03:50 AM
YumYumAudio YumYumAudio is offline
Default MTRX Studio & HD Native
I've just got the MTRX Studio (MS) as a replacement for my dead Omni. I can't seem to get the basics working and the documentation doesn't seem to help, nor does there seem to be any videos covering this online. Basically, I can't see the MS as an Audio Interface for my Pro tools and therefore have the basic function of opening Protools and getting audio in and out.
What I've Done:
I've connected my Digilink Cable from Port 1 in the MS, to Port 1 in the PCI card in my mac. Connected the ethernet port 1 to my computer. XLR's plugged in to Mic 1&2, and the D25 snake in line out 1-8 for 5.1 speakers.
In DADman, on the "CON" section, I've selected AD & Digi Link 1-22 (as shown in the avid MS Install Guide pdf)
In "CONF" I've got DigiLink mode as Pri/Pri
I've noticed that there is no "Protools HD" in Conf, like there seems to be in videos for the MTRX, but wasn't sure if this was MTRX specific, and not the MTRX Studio.
Monitor Profile, I've set out my Source for Pro Tools HD - 5.1 - Digilink 1 Ch 1-6. And outputs DA Ch3-8 (Line 1-6)
I've updated to the latest firmware on the MS.
Is there some step that I am missing here?
My System:
Mac OSx Sierra 10.12.6
Mac Pro 5,1 (mid 2010)
Pro Tools HD 2018.12.0
Old 07-27-2020, 05:49 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: MTRX Studio & HD Native
I could be wrong, but I think you need DADman 5.4.1 or higher and Protools 2020.3 minimum.
Old 07-28-2020, 08:36 AM
creativecontrol's Avatar
Yes, that is correct. MTRX Studio support for DigiLink was added in Pro Tools 2020.3:
https://avid.secure.force.com/pkb/ar...-Release-Notes
The current version of DADman available in accounts is 5.4.2.
best,
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 07-30-2020, 06:20 PM
polyh3dron polyh3dron is offline
The MTRX Studio has a bit of a steeper learning curve than other Pro Tools interfaces, so you'll want to read the entire manual pretty closely. Avid did a series of videos on YouTube introducing people to the original MTRX unit, and most of the stuff they go through applies to the MTRX studio, including how to set up your monitoring section. They also have a playlist of videos for the MTRX Studio that should help. Basically just scour their channel and you will be on the right track:
https://www.youtube.com/playlist?lis...QDeRgOaJw_FSI1
I'm not sure how the networking defaults in the unit out of the box, but the direct ethernet connection between the MTRX Studio and your Mac's Ethernet port could be one of your problems. I believe from memory that it can be used this way after it's set up properly though.
First steps with MTRX Studio SMM Pro Tools HDX & HD Native Systems (Mac) 187 09-09-2020 08:39 AM
MTRX Studio with HD I/O nedd Pro Tools HDX & HD Native Systems (Mac) 20 08-17-2020 07:38 AM
MTRX Studio and MOM Awesomeness DonRWatters Pro Tools HDX & HD Native Systems (Win) 2 07-19-2020 08:42 PM
MTRX Studio - No AES?! Ryan Young Pro Tools HDX & HD Native Systems (Mac) 23 02-23-2020 02:13 PM
MTRX Studio i/o Cheesehead Post - Surround - Video 6 01-31-2020 09:15 AM
