  #141
Old 07-22-2020, 06:05 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: First steps with MTRX Studio
I usually use Beyer DT 770 Pro’s which are 80 ohms and they sound great. Just for extreme comparison I tested a pair of AKG K 240’s and was still able to get enough gain.
best,
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
  #142
Old 07-27-2020, 11:19 AM
Goombot Goombot is offline
Great. thanks. If I wanted to get into a headphone amp optically, can I do that from the MTRX?
  #143
Old 07-27-2020, 11:26 AM
or I can get in AES as well. Are either an option? Obviously AES would be better.
  #144
Old 07-28-2020, 08:44 AM
MTRX Studio has Dante and ADAT Optical for Digital IO - in addition to DigiLink obviously. If you need AES you could add an Audinate AVIO for example:
AES3 <-> Dante:
https://www.audinate.com/products/de...ante-avio#aes3
Jeff
Jeff Komar
S6 FAQ
  #145
Old 07-28-2020, 09:11 AM
Great. That's exactly what I was looking for. Thanks Jeff.
  #146
Old 07-29-2020, 07:44 AM
Here's a new video to get folks up and running with MTRX Studio. Hope it is helpful.
https://www.youtube.com/watch?v=sMb91SVVnF4
best,
Jeff
Jeff Komar
S6 FAQ
  #147
Old 07-29-2020, 06:31 PM
glogulus2003 glogulus2003 is offline
Hi, I’ve got an HDX2 setup with an omni and hdio. I’m going to replace the omni with the mtrx studio and was wondering if this setup should work:
MTRX studio digilink port 1 and 2 to port 1 and 2 of the hdx card 1.
HDIO to port 1 of the the second hdx card. The MTRX and HDIO connected together in a loop.
After reading the documentation this seems like the best configuration to get the most out of this setup. Does this seem reasonable?
  #148
Old 07-29-2020, 06:35 PM
Yes that should work just fine. By a Loop, I presume you mean Loop Sync - which is fine. If so, loop sync out of MTRX ST to loop sync in on HDIO to loop sync out of HDIO into loop sync in on MTRX ST. You can also set your MTRX ST to internal and simply send word clock out of it into the word clock on HDIO.
best,
Jeff
Jeff Komar
S6 FAQ
  #149
Old 07-29-2020, 06:41 PM
Thanks for confirming! So exciting!
  #150
Old 07-30-2020, 05:03 AM
Can you use Hardware Inserts? Absolutely. The only additional step required (from an HD IO for example) is to add the (documented) converter delay into the Hardware Insert Delay field in the IO Setup.
Jeff
Can you provide an example of when, and how, you would do this?
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 06:47 AM
Still no specs on MTRX Studio Avid? corp Pro Tools HDX & HD Native Systems (Mac) 51 04-02-2020 05:31 PM
MTRX Studio - No AES?! Ryan Young Pro Tools HDX & HD Native Systems (Mac) 23 02-23-2020 02:13 PM
MTRX Studio i/o Cheesehead Post - Surround - Video 6 01-31-2020 09:15 AM
analog console, next steps for my studio badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2003 08:03 AM
