Re: How do i change my buffer size?
Has this been fixed? I have exactly the same problem only with Pro Tools 10.
Check with your interface manual/software for instructions on setting the hardware buffers with your interface before you get into ProTools
So in the case of the previous poster set up your pre-Sonus first and then slave your PT to match exactly those settings
Cant change buffer size | shea | Pro Tools 11 | 0 | 01-16-2014 11:38 AM |
So, When change H/W Buffer Size...... | gonsdeejay | Pro Tools 11 | 0 | 07-29-2013 09:12 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Can't Change Buffer Size? | sajack23 | Windows | 5 | 08-05-2012 05:29 PM |
PT9 / Buffer size won't change | narapo | Windows | 3 | 08-15-2011 02:59 PM |
