Old 12-20-2017, 02:10 AM
Stig Eliassen's Avatar
Default McDSP 6050
Does it map properly on the D-Command?
Thanks.
Old 12-21-2017, 11:04 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Re: McDSP 6050
Depends on what you define as "properly" Being a "rack" kind of plugin it kinda doesn't fit into the usual D-Command/ICON mapping flow. You can spill the plugin parameters and dig through multiple pages to find the parameter control you want and it does change the parameter but the parameter values displayed on the D-Command are meaningless i.e. values 1-100 rather than matching the values on the plugin.
I tried really hard for a week or so to find a workflow using the D-Command but ultimately found it much faster and more intuitive to use a mouse.
Great sounding plugin however! You should download the demo and check it out!
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 12-21-2017, 11:29 AM
Thanks for your time, Will.
Poorly explained on my part. I meant how well it maps to the dyn/EQ section on the console. I have done the trial period, but during a period with a lot going on, so I didn't find the time to test the plugin properly.
Old 12-21-2017, 11:52 AM
In a word, poorly. The center section eq/Dynamics only control the first element in the rack, and there are “phantom controls” with some eqs and comps where there is a parameter knob that has a label and level indicator on the knob surround but the knob controls nothing. In addition there are multiple pages of phantom controls depending on the eq or comp with no way of knowing if the knob is actually assigned to anything without looking at the screen.
This plugin is definitely not designed for an ICON series controller. Honestly, I don’t know how anyone could code it to work. Too many variables.
Will Russell
Old 12-23-2017, 02:24 AM
Thanks a lot for sharing the experience, Will. Appreciate it.
I had decided against buying plugins that doesn't map, but we'll see. I do like McDSP.
FS: McDSP 6030 HD v5 & FutzBox Native v5 (for sale with permit from McDSP) Dusty Angel Buy & Sell 3 11-15-2013 07:00 AM
MCDSP ?? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-06-2008 04:06 PM
McDSP Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-14-2007 05:48 AM
McDSP soon on LE... GW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-24-2005 10:00 AM
McDSP for XP Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-12-2004 09:05 PM
