Old 02-12-2014, 12:12 PM
def3mno62 def3mno62 is offline
Default Spacebar Problem
For whatever reason when I press spacebar instead of playing from the previously marked spot it will instead play from the spot I stopped the playback. In other words it basically pauses playback rather than stopping it and going back to the spot where I marked it which is what it was doing until it decided to change for whatever reason... Anyway, anyone know how to switch this back?
Old 02-12-2014, 12:26 PM
Drew Mazurek's Avatar
Default Re: Spacebar Problem
press the "n" key.
www.drewmazurek.com
Old 02-12-2014, 12:31 PM
awesome thanks man that was driving me nuts. must of accidentally pressed it when pressing the spacebar
Old 02-12-2014, 12:47 PM
C C is offline
For visual reference there is button on the toolbar, under the pencil tool, that will turn blue if this mode (called Insertion follows Playback) is turned on. If it is off then the button is grey.
Just FYI.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Can't hit the spacebar without a pop at the end spviii macOS 12 10-15-2012 05:15 PM
spacebar feature jsmusek Pro Tools M-Powered (Win) 4 05-06-2009 11:36 PM
spacebar doesn't always work (again) Bennie Cook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-14-2008 02:59 AM
Possible fix for not playing from spacebar Greg B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-16-2006 10:23 AM
Disabling SpaceBar .. possible? Impala Pro Tools TDM Systems (Mac) 3 07-21-2002 08:24 AM
