Digital Clock Source
Hi all!
I just got an Alesis AI-3 (finally) and though I'm currently only using it for inputs, I connected light pipe to both In and Out so it will sync to the clock correctly. I also have a dbx 376 Tube Channel Strip, which is connected to the S/PDIF connector of my 001. In Pro Tools LE, I then set my Sync Mode to S/PDIF, with the clock rate I wanted also selected. This seems to work fine, with the added 'benefit' that if I forget to set the output clock rate correctly on the dbx 376, the sessions won't even play. Any comments ... did I miss anything? Anything else important I might not be thinking about? Thanks for any and all help. |
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
problem detected with audio clock. check that your clock source and sample rate are c | angeleda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2010 07:09 PM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
Digital Noise Issues - Clock Source Issues? | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2010 01:55 PM |
