Crash after \'bounce to disk\' in 5.1.1
It seems the be a session that is corrupt.( or whats in the session ) It crashes 2 systems while other more DSP hungry sessions bounce to disk fine. Converting or not, bouncing any portion of this session causes a crash at the end of the bounce. A new session was created, tracks imported, still a crash. The only different thing in this session is the use of an RTAS plugin in addition to the TDM. Has anyone else experienced this when using TDM and RTAS simultaneously?
I am running a G4 533mhz, OS 9.1 ,512 RAM, mix++, ATTO dual, Glyph Pro Tools Trip, Appian dual port AGP card. |
Re: Crash after \'bounce to disk\' in 5.1.1
I get crashes after a bounce to disk if ProTools is no longer the front application.
saltminer |
I too had problems 'bounce to disk' when I upgraded to 5.1. After much seaching, scatching of heads, re-boots, different hard disk drivers,scsi cards etc etc... I finally solved it by REMOVING the Newtech G4 processor card out of the 9600 and replacing the original 350mhz card. All is now well. SPEED kills....
System: 350 9600 tdm pt 5.1.1 (now) 888/24 pt24,mix farm,2*farms. 2*9gig scsi drives ATTO scsi card. hope this helps sombody. |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Rob Macomber:
...The only different thing in this session is the use of an RTAS plugin in addition to the TDM. Has anyone else experienced this when using TDM and RTAS simultaneously?<HR></BLOCKQUOTE> -What error(s) are posted? -What RTAS plug-ins are you using in the session? -There is a bug in Pro Tools TDM that causes type 2 errors during a Bounce To Disk when using the D-Verb RTAS plug-in. Brent |
Thank you, thank you, thank you, thank you!!! I save so much time reading the DUC rather that trying to figure stuff out on my own. The bug with D-Verb RTAS was it for me! [img]images/icons/grin.gif[/img]
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade | AllThingsMusicStudio | macOS | 0 | 06-28-2012 07:16 PM |
Bounce to disk crash | Syncronix | Pro Tools TDM Systems (Mac) | 5 | 10-01-2011 05:43 AM |
cancelling bounce-to-disk will crash PT | digidesigner | Pro Tools TDM Systems (Mac) | 6 | 04-08-2009 02:59 PM |
crash when interrupting bounce to disk | jeff markham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-09-2006 07:31 AM |
Bounce to Disk crash | Ozzie | Pro Tools TDM Systems (Mac) | 1 | 06-29-2005 12:59 PM |
