Channels available after adding AD card to 192 I/O
Hello, I'm waiting on the arrival of a Digidesign 8 channel AD card for install in 192 I/O's extra slot. Other than this, this is a stock 192 I/O. Once installed, I realize I will have 16 AD inputs and 8 DA outputs. The 8 channel AES card will remain installed. Can I still use the 8 AES Ins/Outs of the card or will I need to "share" the inputs with the 16 analog inputs?
Thanks in advance!
Armando |
Re: Channels available after adding AD card to 192 I/O
Yes. No matter what cards are installed, you are limited to a total of 16 ins and outs(in any combination of available ports). So, it could be 16 analog inputs, 8 analog outputs and 8 digital outputs(on AES or Optical). Opening the Hardware setup page will show you all the available routing options. Once you have assigned as you need, go to Setup>IO and set up your routing
What you need to understand is the DigiLink cable provides the box 16 ins and outs and you cannot change that. On the hardware setup you can choose which physical i/o you want to route there.
Another 16 ins and outs are reserved for the expansion box.
Ok thanks for the info!
Armando |
I received and installed the AD card yesterday and tried it. Everything seems fine except I'm trying to utilize channels 7/8 of the AES's card's I/O on channels 15/16. I've got AES 7/8 connected to a PCM 81. The PCM is receiving signal but signal is not being returned to channels A15/16. I. It's have something configured wrong in either Setup or the I/O menu.
Any suggestions would be great! Sent from my iPhone using Tapatalk
Armando |
I am. That's what the problem I'm having. It's not returning into the channels set in Pro Tools 7/8(A15/16)
Armando |
Alls well wound up being the pan pot position on the channels fx send.
Thanks again for your suggestions! Sent from my iPhone using Tapatalk
Armando |
Adding channels to an mbox 2 | justin88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-10-2007 01:56 AM |
Adding Channels | pigonthewing1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-28-2005 02:01 PM |
Adding Channels | pigonthewing1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-27-2005 09:36 PM |
Adding channels | SawToothWave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-29-2004 09:40 PM |
