Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 07-15-2013, 07:33 AM
reichman's Avatar
reichman reichman is offline
Default 003 Drivers 11.0.0 & 10.3.3 co-install problem
I'm building a new boot drive with OS 10.8.4.
Pro Tools 10.3.6 won't connect to the 003 Console with 002_003 driver 11.0.0.
If I uninstall the 11.0.0 driver and reinstall the 10.3.3 driver, it works. Avid, any hope of fixing this? Anyone else managed to do the Pro Tools 10/11 co-install successfully with an 003?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 07-15-2013, 08:27 AM
Hurricane Sound Hurricane Sound is offline
Default Re: 003 Drivers 11.0.0 & 10.3.3 co-install problem
Hi Reichman,
I'm trying the same thing on my home rig. Same problem here - once the PT11HD 003 drivers are installed the 003 isn't recognised by PT10HD.
How do you go about un-installing a driver? I am happy to just work with PT10 for now...
Many thanks,
Thom
Old 07-15-2013, 08:30 AM
reichman's Avatar
Thanks for confirming. Twice now I've managed to make it work by doing the following:
1. Launch the 11 driver, choose "uninstall".
2. reinstall the 10 driver.
3. reboot
Until 10.3.6 can use the 11 driver, this is going to be my workaround while I test PT11. Unless of course all my plug-ins are AAX ready tomorrow
Nathaniel Reichman
Old 08-11-2013, 07:15 PM
yaboyv yaboyv is offline
3. reboot
i just put pt 10 and its say the selected asio hardware could not be initialized, it was working, i restarted my laptop now this, im using producer usb
Old 08-11-2013, 07:24 PM
As have been covered by other threads here (have a search) you need to have installed both the 11 and 10 compatible drivers for the 003 to have both work. They can stay installed simultaneously.
Digidesign Audio Drivers Install Problem Batch68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-13-2010 08:48 AM
problem with PT 8 install - digidesign audio drivers returned an error 2147213312 music project 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 38 05-30-2010 11:38 PM
install problem with mbox2 mini / drivers gak7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-22-2010 06:47 PM
Should I install PT 8 before or after I plug in my 002r that will install drivers? Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-05-2009 10:12 AM
BIG PROBLEM Can't Install PT Hardware Drivers CMinti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-30-2004 07:28 AM
