Old 04-13-2012, 06:06 PM
shabbar3 shabbar3 is offline
Exclamation Please help (PT instrument related)
Hey guys so something real odd is happening in one of my session. I used 4 structure free instruments on these tracks. And I tracked it, recorded and basically it all worked just fine...now, yesterday I added another one (5th one) and then it said "Structure free does not allow more then 4"..I was like ok, then i deleted the new one (5th one). Now i thought everything was back to normal but basically all those 4 other strucure tracks were not playing the notes that I wrote for it (midi). I restarted pro tools and still same issue. I deleted all the strucutre tracks and started all over and STILL the sounds arent being played? but now sometning else happened, I used another patch of sounds and it works just fine!! but the old sound patch is now like dead or something, when i browse and transfer and play the keys its just "nothign"..please help if anyone knows what to do
Thanks, Shabbar
Old 04-14-2012, 01:14 AM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Please help (PT instrument related)
Sounds like you may have somehow inadvertently changed setting/s when deleting 5th patch.
Look in Midi editor and make sure all the notes are still there on each track.
Check your Midi channel outputs to make sure they are triggering on the appropriate channels in Structure.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 04-14-2012, 12:02 PM
Don't forget that you can route your 4 instances of Structure to AUDIO tracks and record them as audio. Then you can delete the original 4 and add 4 more
Old 04-14-2012, 12:42 PM
Right right. thanks guys so much, I will do this as soon as i get home from work. I hope you guys are right..
Thanks again
Old 04-14-2012, 11:40 PM
cwsand's Avatar
cwsand cwsand is offline
Or make them inactive.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-15-2012, 12:33 PM
Very true
Old 04-29-2012, 03:53 PM
Ya so I tried what you guys was saying and heres where it gets even weirder, theres only ONE!! patch that is not willing to cooperate. I browse to the right files and I transfer it to the port so I can go head and write the appropriate notes for it, but to no avail. I press all the keys on my midi piano and I can even see like the little dashed yellow light blinking every time BUT there is no sound being produced, which before all this started to happen it WAS working. Please help with this tedious and very frustrating issue.
P.S. i opened up that patch in other sessions and it works great but in THIS session it is just being annoying.
[IMG] code is Off
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
8.0.3 related daslicht Pro Tools TDM Systems (Mac) 8 01-20-2010 04:10 AM
Not really PT related, but need help... Superclock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-24-2008 07:55 AM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
Can I do this with PT? MIDI RELATED GothicV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-14-2005 05:13 PM
