EuControl/Workstation 3.4 now available!
Hi All,
EuControl/Workstation 3.4 is now available! This is the biggest release we've done in a long time with new features and many bug fixes. For a complete list, download the attached Read Me. What's New for S3 • All Pro Tools meter types are now supported. • Enabling a second workstation and general connectivity has been improved. • In EuControl Settings>General, you can toggle the primary function of the Rec/A switch on the Dock, S3, Artist Control and Artist Mix • S3 Audio Control - Direct Out mode lets you use S3 as a small mixer, designate an S3 audio input for talkback, and more. • S3 Audio Control - Single Display mode lets you have all audio parameters accessed from a single Channel Control Encoder (16) instead of eight (9–16). What's Fixed General • Major connectivity improvements for Pro Tools | Control and surfaces when connected directly Mac and Windows workstations • EUCON 3.3 would not connect to different subnets (EUCON-3965) • Automation data from faders and knobs was erratic at approximately 13ms intervals for all EUCON surfaces (EUCON-4430) • Surface Shift + fader cap touch now sets fader value to 0 dB for all surfaces, regardless of whether surface Shift is latched On. Note that this requires that the EuControl Preference Shift + fader sets level to 0dB is enabled (EUCON-2883) • Selecting a track in Pro Tools auto-scrolls to top when going past the bank limits of any EUCON console (PT-207453) • In Pro Tools, enabling EUCON in Setup > Peripherals while there was no surface connected caused Pro Tools to take 10 seconds to quit (EUCON-4054/KAM-4417) • EuControl 3.3.2 uninstaller did not uninstall EuControl (EUCON-4143/KAM-4602) • EuControl was crashing silently on Windows when exiting EuControl (EUCON-4363) • With Windows 8.1, application focus change occured when accessing the System Tray notification area (EUCON-4367) • On Windows, surfaces did not always Add the first time to move them from All Surfaces list to My Surfaces (EUCON-4368) • Meters on some mono audio tracks in Nuendo/Cubase would sometimes not work after banking a surface (EUCON-4158) • Mouse response slowed on Windows 10 after EuControl was installed (EUCON-4128/EUCON-4104) • Windows 10: App focus change now occurs when accessing the system tray notification area (EUCON-4086) • EuControl on Windows (only) did not auto launch on first try when performing an upgrade from 3.3 to 3.3.1 (EUCON-4122) • EuControl 3.3.1 uninstaller did not uninstall EuControl (EUCON-4143) • EuconWS (Workstation Control) installer was not launching MC Client after install was complete (EUCON-4124) S3 • After exiting Multi-Master VCA Spill mode S3 would not go to the previously recalled layout (EUCON-4373) • After closing a session, the Multi-Master Spill indicator LEDs for <Bank and Bank> switches would be on (EUCON-4372) • When a VCA is spilled in Single Master mode, LEDs for <Bank and Bank> switches would be on (EUCON-4432) • S3 Multi-Master Mode Spill would not always unspill on first attempt (EUCON-4383) • S3 would incorrectly indicate Multi-Master Mode after unspilling by recalling a Layout (EUCON-4733) • S3 would not always reconnect to EuControl if powered off and on while EuControl was running (EUCON-3827, EUCON-4754) • After updating S3 firmware, EuControl could crash while Pro Tools was launching (EUCON-4761) OS Compatibility • Windows 8.x 64-bit • Windows 10 • Mac OS 10.10.3+ • Mac OS 10.11.4+ Downloads Log into your Avid account here to access EuControl software. Last, please ensure that you are running the latest firmware for your control surface. Instructions are provided in the attached Read Me.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
EuControl/Workstation v3.3.2 Now Available | Avid | Technical Alerts | 0 | 11-11-2015 02:36 PM |
EuControl/Workstation 3.3.2 now available! | Kyle Splittgerber | Avid S1, S3, Dock and Control App | 0 | 11-11-2015 01:00 PM |
EuControl/Workstation 3.3.2 now available! | Kyle Splittgerber | Artist Series | 0 | 11-11-2015 12:59 PM |
EuControl/Workstation 3.3.2 now available! | Kyle Splittgerber | Avid S1, S3, Dock and Control App | 0 | 11-11-2015 12:58 PM |
EuControl v3.2.1 and Workstation v3.2.1 Release | Kyle Splittgerber | Technical Alerts | 0 | 11-20-2014 01:19 PM |
