Does PT12 open sessions from 9 and 10?
Can't find any info, but seem to recall seeing that it doesn't.
If not, can 12 co-install with 9 on Win7?
http://www.oneearthproductions.net |
Re: Does PT12 open sessions from 9 and 10?
12 will open sessions back to v5.1 here on the Mac. I assume it's the same on PC.
good news. thanks
The only catch might be an older session that was saved on a mac, without the "enforce mac/pc compatibility" box checked. I remember that from PT 5 and 6, not sure when it finally went away, I think it was around PT8.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
There are some reports of bugs opening sessions in recent Pro Tools 12 releases. You can find those threads by searching on DUC or with google. Before commiting to an upgrade, test out what you intend to do with a free Pro Tools 12 demo license (ideally installed on a separate clean boot partition. There is no supported co install of Pro Tools 9 with any other version of Pro Tools, and i suspect it would not work. Last edited by Darryl Ramm; 09-15-2015 at 07:57 AM. |
i think there used to be a way to start a session without loading any plugins .. does this exist or am i crazy ... wait, i am crazy !!!! but does it exist ??
Yes, and it is documented in the same places it has always been. And findable easily by Google. I am not sure what this has to do with the OPs question.
PT12 crashes when trying to open one particular session | javasound | Pro Tools 12 | 53 | 10-13-2015 01:15 PM |
Will PT7 projects open and run in PT12? | doylerdoyler | Pro Tools 12 | 4 | 07-15-2015 04:16 PM |
Where to save your sessions and audio in PT12 | VRW | Pro Tools 12 | 4 | 04-11-2015 11:04 AM |
PT12 sessions in PT11 questions | musicman691 | Pro Tools 12 | 12 | 03-24-2015 08:10 AM |
sessions always open with mix window track list open | jaglance | Pro Tools TDM Systems (Mac) | 2 | 08-03-2009 06:03 PM |
