What does Initialization Error Code: -7 do?
I have found what the (supposed) cause of this error is (firewall/wifi), but can't find anything anywhere that tells me what this error actually does. What does it keep me from doing? Is it going to cause a system or application crash? Will there be an effect that can't be used? What the heck does this error actually do?
I've turned off Comodo, and disabled the wifi card in the computer, but am still getting this error. I tried an alternate firewall, Online Armor, and when it was disabled, PT10 started just fine with no errors. |
Re: What does Initialization Error Code: -7 do?
There is a knowledgebase that you could search for that error but it's not causing problems I say roll with it record away
try updating your iLok drivers
http://www.ilok.com/download-ilok-software.html You may try excluding PT from your security software as well.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Initialization Error Code: -7 | dalecharlton | Windows | 10 | 09-29-2013 06:30 AM |
Code: -7 (Initialization Error) | JasonJN | Windows | 2 | 09-03-2013 04:02 PM |
PRO TOOLS 10 - initialization error code: -7 | LordFoufoune | Windows | 11 | 06-08-2013 07:55 AM |
Initialization Error Code: -7 Help! | cmeier7 | Pro Tools M-Powered (Win) | 0 | 02-07-2013 10:58 PM |
Initialization error code: -7 | lubs7705 | Windows | 2 | 10-12-2012 08:49 PM |
