Old 09-27-2017, 10:59 AM
conorkelly conorkelly is offline
Default LUFS Metering in Pro Tools
Does anybody know of any plugins that measure LUFS at 2 decimal places for example -23.01
iZotope Insight only measures 0.0, the same as all the other plugins i've come across.
Can anyone shed any light on this?
Thanks
Old 09-27-2017, 11:12 AM
reichman's Avatar
reichman reichman is offline
Default Re: LUFS Metering in Pro Tools
There is no spec sheet out there that requires a loudness delivery to the accuracy of two decimal places (at least, I've never seen it and it sounds insane). But if you must, Adobe Audition accurately measures LUFS to two decimal places.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 09-27-2017, 11:47 AM
I agree it is insane however you'd be surprised, I think this is a recently new process that broadcasting has brought in.
Take Vidchecker for example it measures in 2 decimal places, thanks for the suggestion of Adobe Audition however I need a plugin that would be able to analyse and measure at 2 decimal places within the session.
Thanks
Old 09-27-2017, 10:17 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Have you tried the TC Electronic LM plugin? Works great and is on sale for $49 for the stereo version.
http://www.tcelectronic.com/lmn/
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 09-28-2017, 01:31 AM
Thanks for the suggestion Eric, but this meter doesn't measure in two decimal places.
Old 09-28-2017, 05:50 AM
rhumphries rhumphries is offline
... because today's audiences have such acute hearing and have become so sensitive that .01 dB over the course of the program is discernible? That spec is foolish. I'm not suggesting that you don't have to abide by it, but whomever wrote that into the spec is causing more problems than they are solving.
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 10-01-2017, 01:10 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
Measuring loudness to 2 decimal places is OK but you cannot trust it. If you take the different loudness meters and measure the same audio they will differ by one decimal place. That is why the pre-recorded delivery spec had to be given a tolerance because of the variations between meters. So now we have a +/- tolerance of 0.5LU so measuring to 2 decimal places is completely pointless.
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 10-01-2017, 02:10 AM
Pete Gates Pete Gates is offline
^^^^ THIS ^^^^
I was doing some work where I was metering with Avid Pro Limiter and had it spot on -23 but when metering it offline later (I think it was with Nugen), it was slightly different. Could be down to implementation of the K-weighted filter or god knows what. One decimal place is tricky, two is currently very unlikely. If you're delivering to a spec that requires that, you're going to need to meter it with exactly the same software first - bit pricey if it's VidChecker!
Good luck,
Pete
Old 10-01-2017, 03:41 PM
Petevsi Petevsi is offline
I think the Nugen and the Dolby meter show 2 decimal places when they create log files (I'd have to check). I have found that the Dolby meter shows the same as Vidchecker. Interestingly I have found that the Nugen and the Dolby meter differ in the true peak readings slightly, something to do with the way they round up to one decimal place?
Pete
MacPros, GBLabs Space, S1, Dock,
MTRX, Dante, Protools HDX, VoiceQ
www.vsi.tv
Old 10-02-2017, 12:23 AM
Originally Posted by Petevsi View Post
...I have found that the Dolby meter shows the same as Vidchecker...
Ha ha, that’s about the One meter I don’t have!
Pete
HTML code is On
Fastest way to get LUFS Wawili_Sound Tips & Tricks 2 07-14-2015 06:08 AM
Cheap lufs meter stereo only PhiBee Post - Surround - Video 1 07-14-2015 03:57 AM
How to mix using integrated LUFS / R128 DFN Post - Surround - Video 13 11-11-2014 10:12 AM
Theatrical Mix, Dialog in LUFS ? A Plea to the Pros joachim Post - Surround - Video 11 01-31-2013 09:17 AM
Lufs versus Dolby loudness metering Studio Studio Post - Surround - Video 7 01-06-2012 01:42 PM
