PT HD over LE ? pros ?
Hello,
I'm thinking about upgrading my LE Digi002 to HD2 or HD3. I'm wondering about the pros/advantages of HD over LE, in our times of modern computers with great processing power :) I mean, is there any sound quality difference between working at 96/24 in LE versus 96/24 in HD ? On the other hand, since we're still slaves of the 4Gb on 32 bits, there's no difference between LE and HD Ram-wise, right ? My big ram demanding VIs (Trillian, BFD, Kontakt) will still be performing in a less than optimal manner... Or HD will take part of the load ? As far as I understand, the HD cards are just for processing, not for memory, am I right ? Thank you for your advices, Shutiri |
Re: PT HD over LE ? pros ?
There's been many threads on this you can look up, but a couple of thoughts:
The sound quality is determined by the A/D and D/A converters. The ones in the 002/003 are much lower quality than the 192 IO. But if you used a separate good quality converter into your 002/003, then this wouldn't be an issue. Regarding the tdm chips, they only affect audio and plugins in protools, and would not have any effect on virtual instruments, which mostly use your computers CPU. However, they affect it indirectly because by taking the load off the CPU for audio and plugins, that frees up more power to be used by the virtual instruments. |
Until the RTAS engine is sorted out, it's best to just sandbox your VI's and stream them into Pro Tools. Your VI's running separate from PT will perform better than running them "inside" Pro Tools. There are many ways to sandbox and stream the VI's. You can use an external app like REAPER or Vienna Ensemble PRO etc to achieve this. There are other ways to run your VI's independent from PT. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Having used both systems heavily over the years and experiencing the growth of Native power, I can conservatively offer, that for music production, TDM systems no longer have that clear advantage over Native systems. When you consider the power that's just around the corner with the new Intel 6 core processors this starts to become a no-brainer.
Thank you for all of this. I have some questions about these answers:
nst7: Quote:
Shane: so, you recommend BY FAR to stay with LE and get a monster computer, is that right ? Quote:
Thanks! Shutiri |
No, it's 128 when recording at 96k in PT LE. HD is over 256 at 96k. At 44.1k/48k the H/W buffer can go as low as 64(32 on Mac) in native systems. Until PT 8, the lowest HD could ever go was 128. In order to even do 64 in PT 8 HD in 44.1k/48k sessions, you have to use the maximum number of voices which would be 48 Voices (1 DSP) or 96 voices (2 DSP). This of course can eat into valuable DSP on smaller systems etc. Quote:
i7 PC can have more RTAS plug-in instances than it's TDM counterpart and this includes being at a buffer of 64. One Accel card can do 38 Dverbs. 256 total on an HD 7 system using all available DSP. Add delay compensation etc and it will be less than that. Native has caught up, surpassed, and now we have affordable 6 cores around the corner. At this point though, it doesn't matter as RTAS VI's is one of the poorest formats out there compared to everything else. Digi has commented many times on the forum that we will see RTAS improvements in the future. If your doing MIDI productions as you alluded to, stick with native and spend that 15+ grand on outboard that will maintain a high resale value 15 years from now. The solution for now is to sandbox and stream the VI's into Pro Tools. You'll be doing the same workaround on HD. Shane
And with all that said... Shane uses a last generation quad core... and he hasn't maxed out his Complete Production Toolkit.
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
the only thing make me sad with my PTLE, is the 32 mono internal bus limit. That's very limiting if you build a complex send/returns and submix environment. And with MPTK you obtain 48 stereo or 96 mono at 96 khz, the same with CPTK. Is the same with HD1? |
2010-2012 Mac Pros, Imacs, and Macbook Pros do multi-channel HDMI audio out! | nst7 | Post - Surround - Video | 3 | 07-15-2013 04:37 PM |
New Mac Pros due soon!? | M-ManLA | General Discussion | 33 | 06-28-2011 12:49 AM |
New Mac Pros. | sburrows | Pro Tools TDM Systems (Mac) | 1 | 09-01-2010 02:44 PM |
What Do The Pros Mix Down To | Hank5 | Pro Tools TDM Systems (Mac) | 35 | 03-04-2006 11:55 AM |
Need Help from some Pros in the Know | Marc Doudican | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-16-2000 10:48 PM |
