Old 03-04-2021, 08:21 PM
basslik's Avatar
basslik basslik is online now
Default Mac OS Containers ?
I formatted my EVO 970 which partitioned in two. One has High Sierra and the other has Mojave. From what I've been reading I can just create another container and use it whoever, and let's says can I install Big Sur with creating another partition and just create a new container ?
THANKS
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 03-04-2021, 08:58 PM
Sardi Sardi is offline
Default Re: Mac OS Containers ?
You can create another partition and install Big Sur or you can create a container and install Big Sur. The two are fundamentally different and not linked.
Be careful with Big Sur. Since installing and subsequently removing it from a secondary partition on my studio computer, every time I boot into Mojave, the main OS I run, I get an error saying the disk is unsupported or something along those lines. Can’t remember the exact wording. It is not isolated to my machine. Fair few people reporting the same error message online. It doesn’t affect the OS and every works as it should, but it’s annoying to see on every reboot.
Old 03-05-2021, 03:51 PM
basslik's Avatar
Thanks Sardi. Should I create a partition or a container to perhaps avoid that error?. Probably doesn't matter huh ?
Fundamentally different ?
Old 03-05-2021, 06:40 PM
Mine was a partition. I can’t say for certain that the error won’t occur if you use a container.
Might be worth looking it up and seeing if people are seeing that error with containers as well. I think they probably are.
Old 03-05-2021, 10:01 PM
basslik's Avatar
Thank you. I'll hop over to the Mac forum.
Old 03-05-2021, 11:22 PM
Top Jimmy's Avatar
...every time I boot into Mojave, the main OS I run, I get an error saying the disk is unsupported or something along those lines.
Incompatible disk warning. I found that the disk utility doesn't default to showing both the physical drive and partition. It only shows partition/container when opened, but you can go to view and set it to show all devices. I had to reformat at the drive level instead of the container to fix that problem.
James Cadwallader
Old 03-06-2021, 02:26 AM
Yeah that was it.
Actually, I think you’re right. I actually made a container and not a partition.
As I said, doesn’t affect usage... AFAIK. Just annoying seeing it on every boot.
Old 03-11-2021, 08:36 AM
GoButtonGuy GoButtonGuy is offline
In HFS+ and APFS the concepts of partition and container are similar but different in implementation. When you need to segment a disk in HFS+ you use a partition. In APFS it's a container. You can still partition a drive that has an APFS container. This is required for Boot Camp. A partition space isn't able to be shared with other volumes. Container free space is able to be shared among other containers in the system. For most of us that's the big take away.
For those that want to geek out on APFS Apple has this...
https://developer.apple.com/document...le_file_system
What happens in Vegas, we make happen...
Old 03-15-2021, 11:55 AM
basslik's Avatar
Pretty technical. Lets say I have two partitions already. one with Mojave & the other with High Sierra. I want to install Catalina. Should just make another partition to play it safe ?, thanks.
Old 03-15-2021, 02:55 PM
I’d use a bootable drive for the third OS install and run from that.
